Temperature and pop rivets? - Fiberglass RV
Old 10-07-2019, 12:43 PM   #1
Georgana D's Avatar
Trailer: 1990 16 ft Scamp
Could someone please tell me when the best time of year is to replace pop rivets? We want to replace them all in a 16' Scamp.
Thanks in advance!
Georgana D is offline   Reply With Quote
Old 10-07-2019, 02:26 PM   #2
jerrybob's Avatar
Trailer: casita
You can replace them anytime but dry/warmer days make it easier on you...the rivet doesn't care. Good luck.
jerrybob is offline   Reply With Quote
Old 10-07-2019, 03:29 PM   #3
Georgana D's Avatar
Thank you!
I was concerned about expansion if they were done in colder temps.
It's been washed and waxed and some(a good amount) of snap caps are missing. I did buy those through ProDec, but still need to pick up rivets and get er done.
Old 10-08-2019, 06:58 AM   #4
Trailer: Scamp 16, previously Scamp 13
None
If just the caps are missing, and the bottom retaining ring is intact, you can just snap a new cap on. If the retaining ring is cracked or deteriorated, you can temporarily put a new cap on by putting a dab of Marine adhesive caulk on the rivet head, then pressing a new cap onto it. This "temporary" repair can last for years.
If, however, any of the rivets are actually loose or leaking, they should be replaced ASAP. The caulk will NOT seal a leak effectively, at least not long-term.
LyleB is offline   Reply With Quote
Old 10-08-2019, 10:09 AM   #5
Trailer: Trail Cruiser
Pop rivets aren't temperature dependent but your fingers may be, LOL!
Old 10-08-2019, 12:20 PM   #6
Trailer: 77 Scamp 13
In theory the rivet will be tightest due to contraction in cold weather. So if put on in very cold weather one might expect a minor amount of length expansion in really hot weather. So sub zero install and desert summer temps would yield the most expansion, doubt it would be significant as far as holding or leaking even then. But who is going to do rivets in sub zero temps? Extreme need or plain crazy are the only two scenarios I can think of for that.
Since the rivet properly "popped" is under a good bit of compression I imagine (SWAG notice) the compression while possibly a bit less under high ambient temps would still be "tight". Length of metal matters for expansion. So aluminum siding in long strips will expand and contract by a greater length measurement than a short block. Pretty sure the total expansion or contraction of a 1/4 inch long popped rivet is a really small amount.
Old 10-08-2019, 05:01 PM   #7
Rivets and temperature
For ultimate tightness of a rivet, youíd want the rivet hot(longer), and the fiberglass youíre riveting together cold (thinner).
Then when the rivet shrinks as it cools, the fiberglass expands as it warms, the rivet will be in maximum tension.
Of course I donít mean red hot rivets, like older bridges and buildings used.
You also wouldn't have to do it in the winter to have cold fiberglass. But rivets could be heated . Not enough to lose any temper (if they are tempered, I donít know) and not enough to burn anything. Even 150į would work.
Iím sure no one does this, and room temperature rivets have worked just fine for decades.
Stevieboy is offline   Reply With Quote
Old 10-08-2019, 06:37 PM   #8
GOB
Trailer: Scamp 19
replacing pop rivets
When we bought our Scamp 19 the first thing we did was replace all rivets with stainless steel machine screws and all new snap caps. Only took about about 4 - 4.5 hours.
GOB is offline   Reply With Quote
Old 10-10-2019, 06:57 AM   #9
Georgana D's Avatar
Thank you all for your answers. I've never done this so I wasn't sure.
We don't live near the equator or the pole so temp doesn't matter, duh.
Without causing too much debate, when I replace the rat fur I may use screws.
Spindle, Hub and Wheel Temperature JD Eben Towing, Hitching, Axles and Running Gear 43 10-09-2016 09:14 PM
Screws that unscrew and pop rivets that shear off narnold Problem Solving | Owners Helping Owners 3 09-23-2014 05:38 AM
Scamp and the pop rivets Bruce M. Care and Feeding of Molded Fiberglass Trailers 25 05-20-2008 05:57 PM
Replacing pop rivets in a Scamp Sonny Problem Solving | Owners Helping Owners 7 10-06-2006 05:06 PM
Removing pop rivets... How?? Legacy Posts Problem Solving | Owners Helping Owners 4 04-29-2003 07:13 AM
