10-22-2008, 08:48 PM
Trailer: 77 Scamp
CAULK...there I said it...now befor the poo hits the fan here is my question......Scamp and seams between ensolite....I hate the foam tape, its ugly, it falls down in warm weather, and I'm running out of projects. So I'm to lazy to to the master research. Any advice. Do I paint the ensolite first then caulk so as to not "trap" water behind the ensolite or do I caulk then fluff with a sponge then paint and pray that I never get a water leak that I may have just trapped behind the ensolite.......advice please I will take notes and listen!!!
10-22-2008, 09:27 PM
Hi: Brandy... Caulk(paintable latex) type/ Stipple(blend in) with wet paper towel/Paint(latex kit./bath) works great in that order!!!
10-22-2008, 09:57 PM
I couldn't stand the tape. Got rid of it last spring and caulked as Alf says with paintable caulk. Easy to do, took about an hour, let dry and paint.
10-23-2008, 08:55 AM
Trailer: 77 Scamp
any concerns with "trapping" water behind....now as it stands IF *knock on fiberglass* I get a leak I could pull back the sticky tape and see a water trail....with caulk am I creating more of a problem by trapping it IF IF IF I get a leak?
10-23-2008, 09:06 AM
Trailer: 1975 13 ft Trillium
If your egg 'springs a leak' what does it matter IF you have to pull back seam tape or chalk? Just for a second here, I had a brain fart and thought.... <span style="font-size:18pt;line-height:100%"><span style="font-family:Times New Roman">Jello !!</span></span>
10-23-2008, 09:34 AM
Trailer: 13 ft Boler
We got rid of the ugly tape in our Boler 3 years ago and put in paintable silicone. Then painted over and it made an AMAZING difference. The tape wasn't falling out or anything, but it was still the first thing that caught the eye when you looked inside. Now the finish is smooth and only noticeable if you are looking right at it. We've never had an issue with leaks, but should it happen, we would have to tear back the ensolite whether there was tape or not.
10-23-2008, 09:52 AM
Trailer: 77 Scamp
okay one more I see someone said interior paint..but the egg is just as cold as the outside temp when not in use....granted I don't live in minnasota but its still cold enough...
10-23-2008, 10:43 AM
I think "indoor" and "outdoor" paint is more about UV rays than about temperature. That said, there's no reason you couldn't use outdoor paint on the inside, but it's probably unnecessary.
I have not had occasion to use them yet, but I'm hearing raves about the (relatively) new Acrylic Latex Enamel indoor paints (friends have used it on the inside of boats - where conditions are certainly less benign than in most houses - and report long term success).
Note:With either indoor or outdoor paint, the surface has to be warm when you apply the paint. A friend once painted inside apartment walls in winter, and because the unit was unoccupied they had the heat turned down low (especially overnight), so the paint didn't have a chance to dry on a warm wall. They came back the next morning and all the paint had "slid" down to the floor! Oops!
10-23-2008, 11:08 AM
I don't remember exactly what paint we used, but it was definitely an ordinary indoor paint. We live in Alberta (a little further north and west than Minnasota!) and there as been no fading or peeling. It still looks as clean and perfect as it did when we put it on. I did choose to prime it first, but I know others who didn't prime and got just as good results. All based in northern climates too!
10-23-2008, 11:43 AM
.... They came back the next morning and all the paint had "slid" down to the floor! Oops!
unless it was your paint job..... that would be funny to watch in fast forward video or time lapse photo's
that would be a great comedy sketch too. Treat the wall with something nothing will stick too, tell them the wall is prepped for paint and then watch the painters go nuts trying to figure out why an hour later their paint peels off the walls in sheets.
10-23-2008, 11:56 AM
Cruel!
(But funny )
I always loved Candid Camera - although I would have died if they'd found me.
