Thermostat - Page 2 - Fiberglass RV
Old 10-18-2007, 06:19 PM   #15
Brian B-P's Avatar
It's not digital, but according to Honeywell, the T87K is not a simple pair of contacts on a bimetallic spring, like mine:
Power Method - Uses stored power from heating controls.
Sensor Element - Thermistor
and most importantly:
Voltage - 20 to 30 Vac
Also, there are at least two versions of the T87, but
The T87K heat only works with 2 or 3 wire heat only systems
Unfortunately, it expects one of those wires to be from a 24 VAC transformer.
This is a vastly more complex thing than my simple thermostatic switch, which might be fine if it were powered by its own battery... but apparently it's not.
Old 10-18-2007, 06:57 PM   #16
Timmy G's Avatar
Trailer: TM14 Surfside
Yeah ... I just put in a Walmart special ... it works great ... so much for trying to be fancy eh?
Thanks for the advice all ...
Timmy G is offline   Reply With Quote
Old 02-14-2010, 02:34 PM   #17
Wilder's Avatar
Trailer: 1993 Scamp 13 ft
Good suggestions on the Hunter digital thermstat. I was having trouble with the furnace in our 13' Scamp, and just replaced the thermostat with this one from Amazon:
Hunter 42999B Just Right Digital Thermostat
It wired right up per the included instructions for a 2-wire installation and works great! Ahh, heat again )
Wilder is offline   Reply With Quote
The Great A/C Thermostat Mod Patrick M. Modifications, Alterations and Updates 9 08-30-2017 09:26 AM
Fiber Stream AC Thermostat Question Pamela S. Problem Solving | Owners Helping Owners 3 04-24-2010 09:34 PM
Surburban Propane Digital Thermostat. Oliver P Modifications, Alterations and Updates 16 01-14-2010 12:36 PM
Hints for the thermostat power switch? Gina D. Problem Solving | Owners Helping Owners 14 03-11-2007 12:36 AM
Replacing Scamp 16' Thermostat Peter Kienast Modifications, Alterations and Updates 12 01-12-2007 12:09 AM
