Thickness of Scamp roof - Fiberglass RV
Old 06-25-2014, 04:01 PM   #1
Trailer: 2010 Scamp 16 ft
Question for anyone that might know:
My 2010 16' Scamp has the factory installed boomerang antenna on the roof. Last year when i was removing the trailer cover it caught the antenna and broke. I wasn't too unhappy because the antenna was never able to pull any signals in anyway.
I bought a Jack HDTV rotatable antenna from camping world to replace the original. This requires me to drill a 1 1/2" diameter hole through the roof of the scamp for the turn dial inside. The manual says it requires a minimum of 1 1/4" roof thickness. Does anyone know how thick the roof might be before I take my hole saw to it? I know the fiberglass itself is not that thick but I'm wondering what the total thickness is with fiberglass shell, insulation, and rat fur.
Thanks!
Chris
Sent from my SAMSUNG-SM-G870A using Fiberglass RV mobile app
Christopher Phillips is offline   Reply With Quote
Old 06-25-2014, 05:49 PM   #2
Chris,
Perhaps you could construct a spacer or frame of wood to shim out the roof on the inside to accommodate your antenna. Scamp construction is probably less than a 1/2" sandwich, and only the shell is hard material.
Russ
Old 06-26-2014, 08:42 AM   #3
Thanks Russ. That's kind of what I was thinking I might have to do. After I install it I'll post an update.
Chris
Old 06-26-2014, 10:20 AM   #4
Originally Posted by ruscal View Post
Chris,
Russ
I have not removed a vent or cut into a roof of a Scamp that was reinforced for AC installation so can't say how thick it might be but I do know that the roof not reinforced for AC are closer to a 1/4" thick than a 1/2".
Butyl tape: What width and thickness to order? Raya Care and Feeding of Molded Fiberglass Trailers 9 08-21-2015 01:14 PM
Serious Gel Coat Thickness Questions Thee Jimbo Care and Feeding of Molded Fiberglass Trailers 22 09-17-2012 08:12 PM
Boler Frame Thickness Crackedegg Problem Solving | Owners Helping Owners 7 08-23-2012 08:46 PM
Thickness of Plexiglass Karen L W Problem Solving | Owners Helping Owners 12 04-24-2012 04:14 PM
Thickness of scamp foil? DannyH Problem Solving | Owners Helping Owners 2 03-30-2010 08:22 AM
