Tight Termination Cap - Fiberglass RV
Old 08-08-2016, 10:50 AM   #1
Trailer: 2016 -13' Scamp
Massachusetts
After searching the forums without success, I'll ask here: can I lubricate my black tank termination cap to make it easier to twist off when dumping? I don't have a lot of hand strength and the cap is the devil to remove after sitting for a few weeks unused.
I may have to invent a tool that helps me get a grip and get better leverage. I hate holding up folks behind me in the dump station line. Need to get that cap off PDQ! Suggestions?
herons is offline   Reply With Quote
Old 08-08-2016, 11:11 AM   #2
Trailer: Bigfoot B-17 CB
There are several wrenches (spanner wrenches) listed for this application. I have one that the previous owner gave me, but I've never used it. Camco 39756 at Camping World and Amazon have very mixed reviews. For a lubricant, some silicone grease or maybe some Vaseline. Be careful, you don't want the cap to fall off.
Old 08-08-2016, 01:37 PM   #3
IllAnnoy
Take a rat tailed file or a drill and file a notch in each jaw of the cap, leaving the lip intact. This will let the jaw flex easier and it will then go on and off easier. An 1/8" should be enough.
Old 08-09-2016, 11:13 AM   #4
Gilles's Avatar
Trailer: Bigfoot 15B17G, 1986.
Quebec
I use a silicone lubricant, specifically for all plumbing connections accompanied rubber.
As hose connection on the o-ring rubber.
I also use to lubricate the connections between the pipes of my black and grey water tank, after removing dirts that make them hard to handle, and on the rode of the valves.
I am certain to extend far the lifetime of these parts.
At home, when I connect the hoses in the spring, if there is any water leak, I undo connections and lubricates, usually everything stabilizes ...
Silicone Lubricant | Master Plumber®
I found this in a hardware store in my area, I'm sure you have the equivalent in your area.
When buying a new faucet for home, they provide a small amount with the entire system.
Gilles
Bigfoot 15B17G.
Towed with Dodge Journey 2012, 3.6 L., 6 speeds.
Old 08-09-2016, 11:26 AM   #5
Sounds as if you could use a different style of termination end and cap. Why not take a look at that option? They do make easier to use styles.
Old 08-09-2016, 01:06 PM   #6
If you decide to use a lubricant (I personally think is a good idea) I would not use a "petroleum"-based grease. Petro-based grease can cause the neoprene rubber seals to swell and could cause even more troubles if left sitting for some time!
The reason I know this is from experience. I had a B&D kitchen faucet. The swiveling faucet would start leaking because it would get hard to turn and I would try loosening it slightly. I would put a little vasoline on it....which would help for awhile. The next time I would take it apart, the oring was MUCH too large and I couldnt get it to seal right again. Finally the factory sent me some of their "non-petroleum" grease (probably silicone) and that's been several years now and NO more problems and it still swivels easy with no leaks.
Here's a photo of a replacement I used last year. I like it because it has FOUR spades instead of the stock 2. If one breaks (which mine did right before a trip!) while on the road, I can rotate it 90 deg and stilll keep trucking. Walmart was discontinuing these so you may not find them this cheap. I bought 2. Amazon will come close:
https://www.amazon.com/gp/offer-list...&condition=new
Old 08-09-2016, 02:35 PM   #7
Joy A's Avatar
Here's what I use:
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 08-09-2016, 02:37 PM   #8
Ok "Joyous", I give up...where did you get it?
Edit: Ahhh. I guess here would be a good place to start. Good price you paid there.
https://www.amazon.com/Valterra-F02-...erra+sewer+cap
Originally Posted by Joy A View Post
Here's what I use:
Old 08-09-2016, 05:22 PM   #9
Joy A's Avatar
Well Darral, I really don't know.
I've been using mine for well over 10 years
The one in the picture is a spare I carry. I think I've seen them at WalMart. I'm sure just about any RV store carries them, certainly Camping World and that's likely where I got mine.
Joy A. & Lily
and "Puff", too
Waste Termination - No Holding Tank partslady9 Problem Solving | Owners Helping Owners 4 05-30-2013 01:39 AM
Snap cap/Button cap question Kevin K Problem Solving | Owners Helping Owners 5 06-19-2012 11:50 AM
Tight spot Greg Yother Care and Feeding of Molded Fiberglass Trailers 17 04-16-2007 06:30 AM
Tight Quarters in your 13' Egg? Frederick L. Simson General Chat 8 01-17-2007 06:44 PM
Tight Before Christmas Des Nolan Jokes, Stories & Tall Tales 1 12-13-2005 11:18 PM
