Tilted door? - Page 2 - Fiberglass RV
Old 05-03-2012, 08:18 PM   #15
Carol, here's a topic for you! How much scrubbing to get that ensolite clean?
Old 05-03-2012, 08:24 PM   #16
IllAnnoy
Originally Posted by Harvey View Post
On my '84 Scamp 13 the door lockset 'tongue' does not match the striker plate either. On mine the tongue is lower than the striker but probably 75% of the tongue engages the striker. I'm not sure this is the original door on my trailer so that may be a contributing factor?? It had a 'barrel bolt/hasp' type arrangement when I bought it (can still see the 'filled' holes). I've removed that & plan to add a 'flush' type door lockset per instructions by Floyd & DavidSo -
Here's what my lockset looks like now, & the lockset I plan to install by the time my 're-build' is done
One of Eggy-Sue's best mods...
but maybe simply making a wider striker would do the trick.
Old 05-03-2012, 09:25 PM   #17
Trailer: '84 Scamp 13' & 2001 Casita 17' Spirit Deluxe
Arkansas
Originally Posted by Carol S. View Post
Harvey - Wondering what you cleaned the 'elephant skin' (Ensolite) with? We just purchased a 1981 with the Ensolite interior walls and it needs some (medium-duty) cleaning. I tried Scrubbing Bubbles bathroom cleaner on a small area, but it did not clean well without some (actual) scrubbing, and I'm afraid to scrub with too stiff a brush because I don't want to damage it. Any suggestions you could give me would be much appreciated.
Regarding the difference in the wall color and interior door color in your pics, our door is also a different color and texture, same as yours.
Carol, here's pic of everything I used (except the buckets of clean water) - I went to Lowes following suggestion from Sam & Jess, see this thread - Ensolite Interior - Cleaning/Painting ?? - & bought a bottle of Tilex Mildew Root Penetrator. Was a little hesitant about it at first (that stuff is stout!) but after trying it under one of the dinette benches I decided it'd work OK. My trailer was absolutely cruddy inside (it had sat with moisture inside after a leak in the roof vent; most of the elephant skin had at least some mildew & much of it had LOTS). After a few false starts I developed a technique that eventually worked out well for the entire interior. I'd spray the stuff full strength on a small area, maybe 2' square, let it set for 5-10 min & then brush vigorously with the pictured brush (the brush has medium stiff but not harsh bristles) 'til the area was covered with a gray foam. Then I'd take a large synthetic sponge, wet it, wring it out & wipe off the foam, rinse the sponge & continue 'til I'd removed all the foam from that area. Takes a lot of rinsing to remove all traces of the cleaner. Usually a 10qt pail of clean water would last thru 3 or 4 areas before I'd hafta change water. The Tilex cleaner has a very stong, acrid odor so I left the door & all windows open while working, & still had to step outside every few minutes. After cleaning the entire inside & rinsing well it left a nice clean, fresh smell in the trailer. I have a roll of the seam tape from Scamp & after making sure there is no trace of the cleaner still on the ensolite I'm gonna try the s tuff & see if it'll stick, otherwise I'll probably caulk & paint the interior including seams. I still haven't done much 're-build' work inside but that starts this week. Oh yeah, the Tilex works good on mildew & 'tree dirt' outside too. My Scamp had no gelcoat left so I cleaned it well with the Tilex & then applied several coats of Red Max Pro to bring back a shine to the exterior.
Harvey is offline   Reply With Quote
Redoing Burro door hinges - door fell off! AndyW Problem Solving | Owners Helping Owners 10 12-30-2015 11:39 AM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Door Risers.. Door Props.. Hatch Holder upers?? earl squirrel Problem Solving | Owners Helping Owners 2 05-23-2011 05:07 PM
Trillium Door Sahm J Problem Solving | Owners Helping Owners 7 10-26-2008 02:59 PM
Door sag? Legacy Posts Problem Solving | Owners Helping Owners 2 07-13-2003 11:55 AM
