time to add a battery system, could use input please - Fiberglass RV
Old 08-13-2011, 01:53 PM   #1
Trailer: Boler 1300, 1972
I have been happily reno-ing and restoring our '72 B-1300 Boler this summer, and I can no longer put off the electrical. I am comfortable doing the work, I just want to make sure it is done safe and sound.
Currently, there is no battery system. There is shore power that has been wired from the primary junction box to a receptacle in the counter, and a power bar for multiple plug points. The wiring splits off from the receptacle to run to a mini florescent light that was mounted above the sink. There is a mini fridge, about 1.7 cu.ft. (unable to find the spec sticker to get fridge draw) that is plugged into the power bar.
Post renovations, I have removed the florescent fixture, and installed dome style lights to both ends of the top cabinet and both sides of the closet.
For the wiring, I will be replacing the old shore 120v wiring, keeping the receptacle and fridge, and adding a 1000w inverter/charger (overkill for what I will be running off it, but it was a killer sale, so I splurged!)
As I can sort out, the inverter doesn't have flow through DC, so I will have to wire the lights straight to the battery (a single 12v 24 series deep cycle). The Inverter will be hardwired from the 120v shore line, via the existing junction box, as well as hardwired to the 12v battery.
From the inverter I will have a line running to the existing counter receptacle, and I will plug the fridge into the GFCI installed on the inverter. I don;t intend to use the fridge often, so I will have the option of unplugging it from the system easily.
As I understand it, on shore power the inverter will charge the battery when it receives shore power, and will power the fridge when plugged in and power the receptacle in the counter. The dome lights will still run off the battery, but the inverter will manage the battery charge. Off shore power, the inverter will power the receptacle, the fridge (if plugged in), and provide alerts for the battery charge status.
I intend to individually ground each 'power station' to the frame individually. Battery, inverter, and shore junction box.
Here is where the questions start:
Do I need to run separate wires from each light to the battery, or can I run one line to the closet and split off it, and another line to the cupboard and split it as well? Will one fuse for each line be sufficient, or do I need to fuse each light individually?
What gauge wiring should I be looking a from battery to inverter?
What guage wire should I be using for grounding at each system?
Does my plan sound feasible, or should I rethink how I intend to do this install? Any information would be appreciated, If I am on the right track I would love to know as well!
Thanks, sorry for the winded posting, I think just writing this all out has cleared my mind a fair bit as well!
Adam
adriemel83 is offline   Reply With Quote
Old 08-13-2011, 02:13 PM   #2
LukeP's Avatar
Adam,
I have a converter, not an inverter, so somebody else can tackle those specifics.
However, especially if you're using LED lights, they'll have such a low draw that you'll have no problem running 1 set of wires to the closet/cupboard and splitting. I put all of my lights on the same circuit/fuse as well.
On a side note, have you bought the battery already? If not, you may consider a Group 29 battery if you're going to be using an inverter and have a large power need. Unless of course you'll charging frequently. You sound like you've calculated it all out well, so maybe I don't even need to throw that out! Good luck!
LukeP is offline   Reply With Quote
Old 08-13-2011, 02:18 PM   #3
already picked up the battery, but haven't installed yet. most trips will be 2-3 nights, so I leaned towards the 24 series. How much more benificial would a 29 series be?
Old 08-13-2011, 02:24 PM   #4
I guess I should outline the power needs...
-the dome lights are simple 1141 series bulbs, about 1.5amp draw each
-fridge.. .a mystery, need to sort thatone out, but chances are not using it unless plugged into shore anyway
-receptacle will be used primarily for laptop computer a 7amp draw I believe
- charging mini lantern (not sure of draw, but again, not a common usage item)
That is the main power items I can think of off the top of my head. Lights will be primary, everything else is minimal usage
Old 08-13-2011, 03:21 PM   #5
kevin61's Avatar
Trailer: 13 ft Boler and 17 ft Boler
Your fridge will probably pull 10-12 amps when on 12 volt. (If it is a 3 way fridge) Not feasible to use the 12 volt on the fridge unless you have a battery charging system that can keep up with it. If it is a 3 way then operate on propane when you have no power. Even if you don't use the fridge often it usually takes a day to cool down. 24 hours x 10 amps = 240 amps. More than your battery can supply.
Might want to consider LED lights such as these from IKEA. 21 ft of these draw less amperage than One 1156 car bulb.
I put a 1000 watt inverter in mine and truthfully, I rarely use it. To install correctly it needs to be wired in with larger cable, adding expense to your reno. For my low power needs I find the smaller $20 units from Canadian Tire do the job nicely. Up to you though.
You should install a 12 volt fuse panel and a circuit breaker in your positive line.
From inverter to battery is where your larger cables and fuses will be installed.
I'm not exactly sure how the inverter can be wired to your receptacle in conjunction with the shorepower. It can be done with some inverters, however I found it easier to run a dedicated line to one receptacle with an on/off switch. If I want to run an appliance I turn the switch on, plug in, and the 12 volt is inverted to 120V to operate the appliance. This dedicated receptacle is not hooked up directly to 120v.
If you are trying to run your fridge with inverted power from your battery without having an adequate charging system re-supplying your battery at the same time then you will deplete your battery in a few hours.
The Inverter simply inverts 12 volt to 120 volt. It does not charge your battery. It depletes your battery. A Converter/Charger or a Charger alone will charge your battery.
I'm in Calgary, next time you 're in town drop by and I can give you the introductory 12 volt electrical course.
I know electrical seems a bit confusing at first but with time it starts to make sense.
If you come to town, bring your trailer.
Adam[/QUOTE]
kevin61 is offline   Reply With Quote
Old 08-13-2011, 03:46 PM   #6
Kevin61 - wowza, heaps there. fantastic. the fridge is a bar fridge that a previous owner installed, I am guessing there was an icebox originally. No 3-way system in this trailer, unfortuately or I this would be all much easier!
The unit I picked up is an inverter/charger, which I thought would charge the battery while on shore power. Hope I am not mistaken or that is an expensive oops!
Old 08-13-2011, 03:56 PM   #7
kevin61's Avatar
I just checked online and there is such an animal so it should charge and invert at the same time.
I believe Adam has the Canadian Tire house brand of this unit and it will do much of what he asked his questions about.
http://www.xantrex.com/documents/Inv...Rev-A%29-1.pdf
Old 08-13-2011, 03:57 PM   #8
kevin61- on a side note, grounding the trailer towing lights, I am looking at the diagram posted on bolerlife.com My interpretation is that the ground runs from the plug to the frame, then at each light to the frame. Am I reading this correctly? Currently the old ground appears to run the entire circuit then ground to the frame at one point
Old 08-13-2011, 04:05 PM   #9
LukeP's Avatar
Adam, I believe that my 29 is rated at 125 amp hours. I believe that a 24 is somewhere around 80 amp hours? If so, then a 29 would have about 20+ hours more for use (half of the 45 hour difference).
But it all has to do with individual needs.... If your 24 Series has 80 amp hours of power, and you're okay using half of that before recharging (to avoid damaging the battery over time) - then you've got 40 hours to work with. Simple math would say just under 6 hours for your laptop per trip with no lights. Or 4 dome lights x 1.5 amp = 6 amps/hour so you'd get 6+ hours of light per trip, but no laptop.
Kevin has a great write-up and his videos are very nice, I watched them some time ago (thanks Kevin!). He's right, you can get lots of LED light for minimal draw. I changed my bulbs to LEDs - there are other threads going that you may have read too, for reasonable prices.
All of that said - when I had a 24, I'd get thru a wkend fine with it powering a small 12v fan at night and minimal usage of inefficient lights. But when I re-did all of my electrical, I focused on more efficient draw and a 29 - we just camped for 8 days without power and I was glad for it! Which is why power needs are all individual eh?!
Old 08-13-2011, 04:07 PM   #10
Ed Harris's Avatar
I have a feeling you are confusing the term "Inverter" when you mean "Converter"?
It is important as they do exactly opposite functions.
An inverter will turn 12vdc into AC Power but a Converter will turn AC Power into 12vdc.
See what I mean?
From what you describe I think you mean to say CONVERTER?
A converter will supply 12vdc for devices needing this like your lights and will also charge your battery. They also usually have a place available to connect your AC powered things so that when the converter is connected to shore power it runs the fridge in your case,charges the battery and powers the 12vdc stuff too.
So before being able to really help......am I right about the confusion?
It is a common thing.
Ed
Old 08-13-2011, 04:37 PM   #11
Ed
I think that is the simplest way I have seen yet on the comparison of the two.
I think, emphasis on the think, my goal is primarily 12vDC into AC power, However, not used very often. the AC that is. My fiance wants/needs the AC power for her computer (writing off camping trips as travel accommodation), and was thinking the fridge, but not looking like the battery will sustain the fridge.... might be looking into some of Kevin61's 3-way fridges in the future.
I think I am wanting the inverter, as 99% of trips will be with no hook-ups for 2-3 nights. Hoping that is right, cause I already own it!
but yeah, slightly confusing!
Old 08-13-2011, 05:02 PM   #12
LukeP's Avatar
The key is to narrow down what you're trying to power, and when. If you're looking to power 110v / AC items away from shore power (including your fiance's laptop) then you'll need the inverter to run these off the battery. So I too, think you're on the right track!
Old 08-13-2011, 05:16 PM   #13
Ed Harris's Avatar
OK
If this is what you want to do then you really will want both in a sense.
Most Battery chargers will also operate as a converter really and you will need a way to charge and maintain the battery if using an inverter as a main source of power.
I am afraid the fridge is a fairly high power demand item so the bigger the battery the better and it may make more sense to switch to a fridge that already operates on 12vdc as the inversion process will require a lot of battery and also waste power as heat.
Computers already run on low voltage supplies so that would also be easy to find a 12vdc adapter for to avoid needing AC power for that.
I am not sure what you mean by "flow thru dc" but since the inverter will be running from the battery it could just share a connection with other 12vdc sources?
There is a $30.00 device I have seen at Lowes that plugs in between the AC power and a device that will tell you exactly how much current it is drawing.
Seems like a handy thing to have if trying to figure this out.
Sorry to assume I knew what you were thinking too but it is easy to confuse the two.
Old 08-13-2011, 06:03 PM   #14
cpaharley2008's Avatar
You do realize that converting dc to ac to operate a computer that operates off dc is inefficient. Try to obtain as many 12v accessories and install 12v outlets and 12v LED lights. then you can run off your battery. I'm sure you can find a 12v adapter to operate your computer, likewise most LED tv's are also 12v, but they have a little black box that converts 120 to 12v. That is what converter does. You purchase a converter and when you plug in electric, it will operate your 12v and charge your battery.
An inverter just converts 12v to 120v inefficiently (maybe 80%) the rest is lost to heat.
Here is a good reference source
The 12volt Side of Life (Part 1)
Old 08-13-2011, 10:05 PM   #15
kevin61's Avatar
I believe Adam is using the Canadian Tire housebrand of this unit:
Inverter Charger | Freedom HF Inverter/Charger | Xantrex
Yes, it is an inverter and a charger and, from what I understand, it can be hardwired into the the existing 120.
Plug into shore power and it charges your battery and the inverter is bypassed. Someone pulls your plug and it automatically switches to inverter mode.
I either never knew they existed or just didn't pay enough attention to them when I saw them.
Old 08-14-2011, 12:11 AM   #16
That is the unit, re-branded as MotoMaster Eliminator.
Thanks everyone for the abundance of info, tomorrow I should be able to finish setting everything up, and hopefully it all works!
maybe down the road a solar panel will be added to the entire program....
Old 08-14-2011, 05:35 AM   #17
Ed Harris's Avatar
Looks great.
These are more inverter than most put in tiny rigs like ours but they are quality units for sure.
Like I said before the battery is now the crucial variable for you but if you already have one just plug it in and see how long it runs.
Have fun
Old 08-14-2011, 05:57 AM   #18
Pam Garlow's Avatar
Trailer: U-Haul 1985
The MotoMaster does not work as a converter also, correct? I'm greedy, I want it all in one unit Is there such an animal?
Old 08-14-2011, 06:46 AM   #19
Ed Harris's Avatar
I have spoken with Xantrex about this several times and they assure me that these will work as converters too as we know them.
If you look at the specs they will charge at 20 or 40 amps depending on the model and this is roughly 1 20 or 40 amp converter then.
Converters are just Power Supplies really and the current rating is saying how powerful they are as a power supply.
They also are designed to taper the output voltage and current to the battery to properly maintain and condition each different type of battery but they are still really just a power supply(converter).
The charging current is what makes any charger function as a converter but this also interacts with how the charging function will work.
In other words if also powering loads in the trailer on 12vdc the charger will think the battery is more discharged and alter the charging based on this.
I am fairly certain most converters work this way and I have never been able to get any manufacturer to clear this up to my satisfaction or commit to an answer I could understand any better?
I wanted to know because I also have a few True Charge units like those in Kevins video and needed to know if they would act as a converter and high quality charger.
They do and did and I removed one from a trailer when I sold it as they are much better chargers than most designed for an RV.
My understanding is that the unit talked about here is essentially the same charger with a quality inverter in the same chassis.
Another interesting point is that Xantrex made an RV converter for a short while that looked like other converters but then stopped making it.
As I understand it this low end of the market is just not where they wanted to be and they pulled back to their roots somewhat.
Old 08-14-2011, 06:58 AM   #20
kevin61's Avatar
I ended up frying my 20 amp xantrex charger by accidentally shorting it out (beer and 12 volts don't mix) but it did work nicely as a converter. It had a selection switch for a constant 13.5 volts. in this stage it didn't need a battery in the system to operate 12 volt.(they also recommend that a battery not be in the system while in this mode) I am not sure about my 10 amp Xantrex Truecharge seen in the video but I believe it needed a battery in the system to operate,
To my understanding this is somewhat what a converter will do. A converter doesn't need a battery in the system but will also operate with a battery in the system without damaging the battery. When plugged in the converter "knows" to convert 120v to 12v while the charger re-charges your battery.
I couldn't find any information in the manual for Adam's inverter/charger so I believe it will operate as Ed has indicated, charging your battery accordingly, depending on the load that is being placed on it.
battery
12v system - got to redo the Suehaul input please Pat B Ohio Care and Feeding of Molded Fiberglass Trailers 20 04-11-2009 04:14 PM
New battery- what type for future solar system? LizP Problem Solving | Owners Helping Owners 15 02-26-2009 06:30 AM
Dual Battery System ???? Gerry Problem Solving | Owners Helping Owners 6 10-18-2006 04:31 AM
12v system work just on battery McClure Problem Solving | Owners Helping Owners 9 08-21-2006 08:50 PM
I NEED YOUR INPUT ; Legacy Posts General Chat 23 08-03-2003 12:10 PM
