Tiny 3000btu AC unit?! - Page 2 - Fiberglass RV
Old 06-13-2012, 07:22 PM   #15
Holy shock value Batman! At those prices, does it come with a lifetime supply the power to run it?
Old 06-13-2012, 08:46 PM   #16
5000 just satisfies our cooling needs and barely satisfies us when the camper is in direct sun light. 3000 btu is too low.
Markz is offline   Reply With Quote
Old 06-17-2012, 04:37 PM   #17
dylanear's Avatar
Trailer: 2001 Scamp 13'
Good to know!
Now, the main thing I need are some good outside vents for the side of the trailer. Something that will keep bugs and most importantly water, out of the trailer in wind, during towing, even in rain. But that will flow enough air to keep the unit working efficiently.
I talked to Scamp and they said they stopped putting in closet units because the older units that were reliable installed that way are no longer made. They say most window units are made to have unimpaired air flow and putting them in an enclosure makes them work extra hard and they are not built to last that long in the best of circumstances. At $160 pop it's not horrible to contemplate a new one every few years financially, but I HATE disposable crap ending up in landfills. Scamp said they'd go out of business if they had to warranty the installation of today's closet units.
May need to add a few large muffin fans to keep the air moving through the system.
dylanear is offline   Reply With Quote
Old 06-17-2012, 04:38 PM   #18
dylanear's Avatar
Oh, also, on whatever vent I use, some way to close it off will be needed. This trailer will see plenty of cold weather and loosing warmth through the AC unit is unacceptable.
Old 06-21-2012, 07:35 PM   #19
Trailer: Trillium 5500 1980
I had a 5,000 BTU unit in a 13 feet Trillium. In Mexico, interior temperature was 90F degrees (without humidity!!!) and it was 102F outside. It is not overkill. As a matter of fact 8,000 would be preferable. Forget about 3,000 BTU. This is useless.
Normand Choiniere is offline   Reply With Quote
Old 06-21-2012, 10:08 PM   #20
Trailer: Uhaul CT-13
Ohio
Originally Posted by normand choiniere
i had a 5,000 btu unit in a 13 feet trillium. In mexico, interior temperature was 90f degrees (without humidity!!!) and it was 102f outside. It is not overkill. As a matter of fact 8,000 would be preferable. Forget about 3,000 btu. This is useless.
+1000
Panoz77 is offline   Reply With Quote
Old 06-21-2012, 10:33 PM   #21
dylanear's Avatar
Already forgotten. I have a 5000 BTU unit still in the box up at the campground.
Hopefully that'll be enough, I can't easily fit anything bigger/heavier.
I assume there was little shade in that circumstance?
I'm mostly concerned about cooling it down at night in high humidity. I just can't sleep when I'm sweaty. In a dry heat, with an iced beverage, I'm ok in the Scamp when it's 90 inside. I've seen that in New Mexico this year. Not ideal, but I can live with it. Or certainly sitting outside under the awning in 90 degrees.
Ideally I think someone (and it may be me) should design a sun screen made of light weight tent materials and poles that attaches to the roof, just enough to clear the roof vents. something that blocks the sun from directly hitting the trailer, yet will let wind pass over/through.
Trying to effectively AC something baking under strong direct sun is an uphill battle. And with such a shade you might not need AC nearly as much.
Tiny air conditioners Davie B Modifications, Alterations and Updates 59 08-15-2015 07:14 PM
Tiny Propane Tank Valerie G Problem Solving | Owners Helping Owners 20 03-22-2015 05:08 PM
A very tiny trailer jen b General Chat 19 09-23-2012 08:27 PM
a tiny mod... sfoss Modifications, Alterations and Updates 5 04-15-2012 07:36 PM
