Old 05-28-2012, 03:53 PM   #1
dylanear's Avatar
Trailer: 2001 Scamp 13'
Tiny 3000btu AC unit?!
I've found a tiny 3000 BTU AC unit, but it's made for industrial cooling and while I have not found any published prices I expect it to be many times the price of a cheap household unit. But it's tall, very thin form factor is quite interesting! I've heard it said that 5000btu can be overkill in a 13' egg. Will 3000btu be enough? My egg is about 6x10x6'. The 5000 btu units are often rated for 150+square feet and those are in 10' tall rooms, so would 3000btu be enough for a mere 60ft square x 6' volume?
Enclosure Cooling Air Conditioners
IQ3000MMR-126 3000 120V 6.0Amps 45lbs 30.02"Hx6.49"Wx6.02"D
Weighs 10 lbs more than a 5000btu window unit, but it should mount easily in the closet, over the axle, with just a few small vents to the outside. And there'll be a lot more closet left usable than if I stuff a window unit in there. If it's $500 may be doable, but if it's much more I'll have to use the lighter, more powerful, larger window unit.
Anyone else have thoughts on this?
dylanear is offline   Reply With Quote
Old 05-28-2012, 05:35 PM   #2
cpaharley2008's Avatar
Trailer: 2012 Escape 19' with Ram Hemi or FJ Cruiser
Reminds me of the old computer towers from the 80's.
Old 05-28-2012, 05:36 PM   #3
Trailer: looking
Saskatchewan
I don't see how it would be a bad idea, though It probably will be way more the $500, never know though. As for BTU, it should be plenty.
Orcus79 is offline   Reply With Quote
Old 05-28-2012, 05:36 PM   #4
Sue and Henry's Avatar
Trailer: 1982 Burro 13 foot
This sounds very interesting. A thought though: the cooler housed in the small room next to my old classroom has a cooler with the same designed purpose as this one. It is very loud. You might check and compare the measured sound before you purchase. If you go with it please share. If it works, it would be a great solution.
Sue and Henry is offline   Reply With Quote
Old 05-28-2012, 06:40 PM   #5
Trailer: Uhaul CT-13
Ohio
In high 80 to 90+ degree heat and humidity my 5000 btu just keeps up, it is not overkill.
Panoz77 is offline   Reply With Quote
Old 05-28-2012, 06:48 PM   #6
dylanear's Avatar
Other have different experiences. Probably differences in shade and humidity have an effect, also one manufacturers 5000btu isn't always the same as another's 5000btu. Also age and condition of the unit will likely have an effect.
"And finally mounted. It was a hot day, the camper was roasting. That 5000 btu has the capability to cool it far below comfort level."
Air Conditioning a 13 ft Scamp
Old 05-28-2012, 06:51 PM   #7
dylanear's Avatar
Yeah, that has crossed my mind and will be one of my first questions. I want to get clear on how the thermostat works etc.
Good chance this unit is not suitable, but it's worth looking at. It may be too expensive, and who knows how well it'll cool a hot trailer in direct sun. May be an expensive experiment.
Old 05-28-2012, 06:55 PM   #8
dylanear's Avatar
How is your AC unit installed? Closet? Or outside/window?
I have a feeling a closet install without good airflow may be inefficient/ineffective compared to having most of the unit exposed to fresh air.
Old 05-28-2012, 08:19 PM   #9
Ohio
Outside window mount, but good guess. Go ahead and buy an overly expensive 3000 btu unit, just giving my experience, have fun with it. 5000 btu is just that, if that is what it is rated, that is what it is.
Just curious, do you open your door much when camping? You tend to loose some cool air.
Old 05-28-2012, 09:27 PM   #10
dylanear's Avatar
I value your input. Just trying to perhaps stir a technical debate about the descrepancies in people's experiences. I'm assuming there is a technical reason and you folks aren't just making this stuff up! I fully acknowledge this is very possibly an expensive frustration when we know small window units like yours can be very satisfactory. Sorry if I came off rude, that wan't my intention.
Just trying to gauge just how crazy the idea is and I appreciate your reality check. I still want more data on these units.
Old 05-28-2012, 09:33 PM   #11
dylanear's Avatar
Oh, and the door. If I was in and out of the trailer a lot I probably wouldn't have much of an expectation of keeping it cool. It's for resting mostly.
Muggy hot nights are probably my worst nightmare. Can't sleep when sweating!
Old 05-28-2012, 10:15 PM   #12
Maybe, but I'm not willing to give up a window to the air conditioner unless I'm really forced to.. I like all the light I can get inside my little burro. I'm measuring that closet to see if I can find a portable to fit. It will mean losing what little storage there is and a vent cut which I don't like, but heat and I do not get along. Please post what you find.
Old 06-13-2012, 06:21 PM   #13
dylanear's Avatar
I have enough science experiments going on right now, I went with a standard 5000btu Frigidaire window unit with the remote and digital thermostat.
I'll post pictures as I install it.
Old 06-13-2012, 07:16 PM   #14
Trailer: '81 Burro
It's a lot more than $500.
Search Results - EnclosureHub=
Jim_B is offline   Reply With Quote
A very tiny trailer jen b General Chat 19 09-23-2012 08:27 PM
Tiny air conditioners Davie B Modifications, Alterations and Updates 32 05-17-2012 07:09 PM
a tiny mod... sfoss Modifications, Alterations and Updates 5 04-15-2012 07:36 PM
Tiny Propane Tank Valerie G Problem Solving -- Owners Helping Owners 19 05-16-2009 12:09 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
