Tip for threading wiring - Fiberglass RV
Old 08-05-2010, 08:25 AM   #1
Trailer: 1980 16 ft Scamp (Restored)
To thread wiring through tough areas of my trailer, I first push 3/8" clear plastic tubing through the route, then push the wires through the tubing. I use clear so I can see where the wire is at if needed. You can leave the tubing or pull it off as desired when done.
Lawrence W is offline   Reply With Quote
Old 08-05-2010, 09:15 AM   #2
Joe Z's Avatar
Trailer: 16 ft Casita Spirit Deluxe
real nice tip with the clear tubing...... I need to run some wires in another application and will use your tip.
thanks,
Joe
Old 08-05-2010, 07:18 PM   #3
Matt in SV's Avatar
Trailer: U-Haul VT16
There's also some lubricant that you can coat the wires in if you have a problem with them hanging up on vinyl or fiberglass. It evaporates and doesn't leave a residue. It might be useful if you're using somewhat sticky vinyl tubing as a wire chase:
Klein Tools Premium Synthetic Clear Lubricant - 1 Qt - 51028 at The Home Depot
Planning our next Escape!
Old 08-05-2010, 08:01 PM   #4
If you use dry tygon tubing you can tie a small piece of cotton ball to a length of stout button and carpet thread, then take a piece of duct tape and tape over the end of your shop vac,poke a hole in the duct tape and suck the thread through the tubing , then tie the thread to the wire and pull it through.
Old 08-06-2010, 08:04 AM   #5
Joe Z's Avatar
Another Great Tip that i will definately try
Joe
Useful Tip Perry Mac Donald General Chat 1 01-29-2010 01:08 AM
Furnace Testing Tip Time K General Chat 2 12-15-2008 09:18 AM
Threading the Needle... Matt O'Bryan General Chat 12 08-25-2006 08:11 PM
Safety Tip Toodie General Chat 3 08-24-2006 08:09 AM
Safety Tip Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
» Trailer Showcase
Scamp
BSA
Little Trill
Delybo
