Tire pump - do you have one in your trailer? - Page 2 - Fiberglass RV
Old 05-10-2010, 06:15 PM   #15
HerseyBA's Avatar
Trailer: Casita Spirit Deluxe 17 ft Hybrid
I carry an inexpensive air pump that works off the cigarette lighter plug all the time in my tow vehicle (whether i have the camper with me or not).. I also carry inexpensive tire repair plugs and the tool so if i get a flat i just throw a plug in the hole with some rubber tire glue cut it off even with a knife and air it back up ....done and i don't even take the tire off the vehicle.
someone showed me years ago that if you don't have the tire plugs just take a sheet metal screw off your vehicle somewhere and screw it into the leak on the tire.... I did it a few times and it amazingly doesn't leak but i fix it the right way when i get back home.
Joe
The off roaders take tubes of super glue with them to fix flats. Stick the tube of glue into the hole, squeeze out the whole tube, remove, and let the glue setup. Saw a guy do this out on the trail down at Big Bend. Once he aired up, he finished the trail and drove home. Same principle as the sheet metal screws. I think I'll throw a few screws in the box with the super glue. Thanks for the tip.
HerseyBA is offline   Reply With Quote
Old 05-10-2010, 07:15 PM   #16
Joe Z's Avatar
New River AZ
Like the tip about the super glue.... never thought of that but an air compressor of any type is still mandatory to finish the job.
Joe
Joe and Linda
2013 Casita SD
Dodge Ram 4x4
Old 05-13-2010, 12:17 PM   #17
Trailer: 84 16 ft Scamp
I carry Harbor Freight's finest 12 v air compressor, mostly to inflate the auxiliary air bags I installed on the back of both our pickup and Jimmy. I removed approx 1/2 the leaves of the leaf springs and then use the air bags to level the vehicle. Makes 'em ride almost like a Cadillac!
Water Pump Diane H Problem Solving | Owners Helping Owners 10 07-19-2013 07:09 PM
Tire pressure on new trailer tires Tony Nowak Towing, Hitching, Axles and Running Gear 9 09-04-2009 05:14 PM
Spare tire on back of trailer Kevin K Problem Solving | Owners Helping Owners 4 05-09-2009 08:45 PM
Trailer Tire facts info Ken C Towing, Hitching, Axles and Running Gear 16 12-02-2008 10:34 PM
trailer weight , tire pressure , sagging axle Legacy Posts Care and Feeding of Molded Fiberglass Trailers 2 05-17-2003 11:40 AM
