tire size - Fiberglass RV
Old 10-07-2013, 11:37 AM   #1
Trailer: Scamp 16 deluxe
Wisconsin
tire size
On a Scamp 16, what is the largest tire and rim that can be put on without making major changes? Thanks for any reply.
Dick Johnson is offline   Reply With Quote
Old 10-07-2013, 06:41 PM   #2
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I couldn't tell you for sure either way, but there are soooo many variables in this.
What year? New or old axle? Ride height picture? factory lift installed?
Old 10-07-2013, 07:11 PM   #3
Trailer: none
I put 205/75R-14 on my scamp 16 ft, probably original axle (96), did radius the fiberglass especially on lower front curbside about 1/2 to 3/4 in to not have any issues with tire rub
Hambone is offline   Reply With Quote
Old 10-07-2013, 08:08 PM   #4
Trailer: 2014 Escape 21
Virginia
Tom
I was looking at my S-16 the other day thinking about putting on 14's. I thought the curb side looked to be a little tighter fit than the drivers side.
Eddie
Old 10-08-2013, 04:51 PM   #5
Trailer: none
Eddie
if you measure from the belly band down to the same spot on both side you will see, the curb side is longer and curves under more than street side. 14's fit in my wheel openings except for front curbside. I just drilled out rivets for trim and radiused the openings a tad 1/2 to 3/4 inch I believe. re installed trim
Old 10-08-2013, 06:04 PM   #6
Virginia
Tom
I knew that on the S-13 the door flare made a difference around the wheel well but I did not realize it extended back that far on the S-16. What you did sounds like a plan.
Thanks Eddie
Old 10-08-2013, 06:11 PM   #7
Trailer: none
I actually found about the curbside lower body extending lower (and it goes almost to the middle of the scamp logo) was when I was trying to line up cutout for outside hatch cover.
Old 10-08-2013, 11:23 PM   #8
Jared J's Avatar
Kansas
I had to trim the curbside on my 19' when I put 225/75/15's on it, interesting.
What tire size Andyman Problem Solving | Owners Helping Owners 23 04-14-2013 01:33 PM
tire size? Cricket General Chat 0 10-05-2012 01:10 PM
Tire size trailerlust Problem Solving | Owners Helping Owners 0 04-21-2012 05:42 PM
Tire size? aimeelightsey General Chat 15 05-08-2011 08:02 AM
Tire Size Pat C Problem Solving | Owners Helping Owners 2 04-08-2010 09:46 PM
