tires 13 vs 14 inches - Page 3 - Fiberglass RV
Old 01-20-2015, 06:49 PM   #41
Thanks for the heads up on the trailing arm.
The axle can easily be relocated forward. My axl happens to be an AL-KO, but I assume that the measurements are the same.
I might move the axle slightly to properly balance the trailer. I am in the process of a major rebuild and modifications.
I woudl use the AL=KO replacement or the Dexter, but I don't know exactly the angle of the trailing arm and therefore the trailer ride height,
As a part of the rebuild I intend to install a set of red AL-KO shockabsorbers. These clip into the euro AL-FO trailing arms, but with the removable Flexride arms I can machine the mounting grooves into the arms or weld them on.
I would like to add shock absorbers ad part of the modifications.
My worry is the rebound clearance for the tires to the top of the wheel wells.
tires
RAV4 people: why is my hitch only 4 inches off the ground? lpk49 Towing, Hitching, Axles and Running Gear 219 02-11-2017 06:30 AM
Replacing my tires & rims... do they have to be trailer tires? David Scott Towing, Hitching, Axles and Running Gear 20 10-16-2012 07:25 PM
What's the number of inches? Kevin K Problem Solving | Owners Helping Owners 9 02-07-2012 09:46 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 11:33 PM
doing the math... squeezing inches Michael M Problem Solving | Owners Helping Owners 5 11-16-2007 08:41 AM
