tires - Fiberglass RV
Old 06-17-2006, 05:14 PM   #1
I ordered 3 mounted 175/80-13 tires from a local tire dealer . He said they would be Goodyear. Well, when they came in they were Milestar tires(made in Korea). I did not take them because I know nothing about them & felt they were of low quality.
What trailer (sc) tires are campers buying?
Don Meyer
Don Meyer is offline   Reply With Quote
Old 06-17-2006, 07:35 PM   #2
Trailer: Burro 17 ft Widebody
The ST rated tires I got were from Les Schwab with a name that told me nothing. Looked up the code and they were made in Israel as far as I could determine. No problems so far.
Old 06-17-2006, 08:35 PM   #3
Tom Trostel's Avatar
I bought my Goodyear Marathons on-line from Tirerack. The Marathons were made in New Zealand. Tom Trostel
http://www.tirerack.com/tires/tires.jsp?ti...Marathon+Radial
Old 06-18-2006, 07:23 AM   #4
Craig Nold's Avatar
Trailer: 1999 Casita 16 ft Spirit Deluxe
I had not heard of TowMaster tires by Greenball but on the recommendation of my local dealer, I tried them on my Casita. After four years, I’m still very pleased. They made the trip to Alaska and still look like new after more than 20,000 miles.
http://www.greenball.com/home.html
Craig Nold is offline   Reply With Quote
Old 06-18-2006, 04:22 PM   #5
Nick's Avatar
Trailer: 17 ft Casita Spirit Deluxe
Metal valve stems are a good investment too. Lost one tire three years ago due to a valve stem failing. Had a good friend lose one for the same reason..
Nick
Nick is offline   Reply With Quote
Old 06-18-2006, 04:29 PM   #6
Al V's Avatar
Send a message via Yahoo to Al V
Towmaxs here outlasted 2 Goodyear Marathons now
side note all 3 Goodyears that came with the Casita all failed in 18 months last 2 within 500 miles of each other .
maybe a bad batch but iam still stuck with the bill and the mess
Al V is offline   Reply With Quote
Old 06-18-2006, 05:16 PM   #7
Bill MacDermod's Avatar
I am running UHaul bias belt tires made by Goodyear in Indonesia, had them going on 4 years and not a wimper out of them. As for steel valve stems, I think they are still rubber where they enter and exit the rims, the so called rubber that your not sure about are steel on the inside with a rubber coating on the outside. If they were to break off they would both break in the same place, right at the rim. Both are inserted in the rim the same way, they start them from the inside, screw a thingy to the cap threads then lean the thingy on the rim to pull them through. Years ago the made a solid steel one threaded all the way down with a rubber seal then a round threaded nut to screw it down tight to the rim. I remember the rubber washers would deteriorate and the stem would fail. I have not seen these in 40-50 years. Oh yes, I'm still a bias belt fan when it comes to trailers
Love being Inneggsile
Bill MacDermod is offline   Reply With Quote
Old 06-18-2006, 08:23 PM   #8
Nick's Avatar
Bill stated
Bill I beg to differ with you. The rubber valve stems that I was refering to were rubber except for the threaded brass sleeve that the core and cap thread into and over. The area that passes through the rim is rubber and that is where they broke. I said they because the one on the other tire broke when the tire store owner applied slight sideways pressure on it.
I was relaying my personal experience to alert people to a possible cause of some of the on going tire problems .
Bill stated
Bill I'm really supprised that you have not seen any of them in 40 -50 years. That type valve stem is still made and they are used on many racing cars and heavy duty applications. They use synthetic washers now and have no problems with deterioration
Nick
tires
P185-80 tires OR ST185-80 Tires ericmarlo Towing, Hitching, Axles and Running Gear 28 09-01-2023 12:35 PM
Replacing my tires & rims... do they have to be trailer tires? David Scott Towing, Hitching, Axles and Running Gear 20 10-16-2012 07:25 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 11:33 PM
ST Tires Pete Dumbleton Towing, Hitching, Axles and Running Gear 7 04-13-2008 09:37 PM
Need new tires Don Davis Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
