Tongue jack spring problem - Fiberglass RV
Old 10-08-2014, 07:43 PM   #1
Name:	ImageUploadedByFiberglass RV1412818873.338590.jpg
Hi. I pulled the pin to lower the tongue jack this morning and it came apart, dislodging a small washer and I can't figure out where it goes so the spring works properly. This is obviously an I.Q. test that I am failing
Does anyone know how to put it back together? Thanks in advance.
Dave
stewed1 is offline   Reply With Quote
Old 10-08-2014, 07:48 PM   #2
Originally Posted by stewed1 View Post
Attachment 77339
Dave
The problem is the retaining bump has worn off. I had my brother weld a new bump after I purchased a replacement.
The washer goes on the end closest to the frame. When you pull on the handle the spring compresses.
If you look closely at the end of spring or bit closer to the handle you find remains of the bump. I suppose a person could drill and tap a small hole and put short screw in. I don't know that I would want to drill all the through which would weaken the shaft and could cause a failure when you're in the trailer.
Byron Kinnaman is online now   Reply With Quote
Old 10-08-2014, 08:54 PM   #3
Thanks, Byron. I appreciate the info.
Old 10-08-2014, 09:07 PM   #4
The pin in ours has a hole through it with a cotter pin to hold the washer.
Old 10-09-2014, 06:57 AM   #5
Victor Benz's Avatar
Agree on the cotter pin. I had one, cotter pin wore out, and I replaced it with a roll pin, sometimes called a spring pin; see below.
Spring pin - Wikipedia, the free encyclopedia
Victor Benz is offline   Reply With Quote
Old 10-09-2014, 08:17 AM   #6
good idea on the roll pin, they are harder and more durable than a cotter pin. I have plenty of them too in all sizes, should have thought of that.
Tongue Jack Stand fits 2" jack FTTRV Commercial Posts and Products 7 06-20-2014 08:53 AM
Trailer tongue power jack The Hobo General Chat 9 02-24-2009 01:52 AM
Tongue Jack Replacement? Parker Buckley Problem Solving | Owners Helping Owners 8 12-03-2007 08:06 PM
A Frame tongue jack Timmy G Problem Solving | Owners Helping Owners 5 11-25-2007 10:31 AM
Tongue Jack Parker Buckley Problem Solving | Owners Helping Owners 16 11-14-2007 08:06 PM
