Tongue Weight - Fiberglass RV
Old 07-04-2006, 07:35 PM   #1
After checking the tongue weight (or hitch weight) on my 13' Trillium (by means of a bathroom scale), I was surprised to see it weigh in at 260lbs.
The manufacturer certificate inside the trailer cupboard states the tongue weight to be between 115 - 130lbs. I know it is usually around 10% of the total trailer weight.
There is a half full 20lb. propane tank and a battery (22lbs) attached to the tongue and the trailer is not loaded with any cargo.
Any thoughts on why the trailer tongue is so heavy ??
Carl
chemong is offline   Reply With Quote
Old 07-04-2006, 07:39 PM   #2
Trailer: Fiber Stream
Thumbs up
Carl
Are you placing the hitch coupler (Ball Socket) on the scale? Or the Jack stand?
Old 07-04-2006, 07:47 PM   #3
To ask another question. Is the trailer level?
Old 07-04-2006, 08:48 PM   #4
Thanks for the replies...
The trailer is level. I did place the jack stand and not the coupler on the scale... I'll try that tomorrow.
Old 07-04-2006, 09:26 PM   #5
Best way to find true hitch weight is to hook up the trailer to the tug and measure the height to the top of the ball/coupler. Now unhitch and weigh the tongue at that coupler height. The fulcrum effect can cause the weight to be more if you are weighing "tongue down." The reverse is true if "tongue up." And what you're trying to figure out is the exact weight at tow height on your particular tug.
Old 07-04-2006, 11:59 PM   #6
Pete Dumbleton's Avatar
Bear in mind that the manf stated tongue weight is often based on a percentage of the dry weight before options; that's just the way a theoretical trailer comes from the factory and is not a true, operating number.
The real-world tongue weight should be based on a SCALE weight of the trailer with its normal operating load of water, LP, food, clothing, pots, pans, etc.
weighing, weight
tongue weight Rob M Towing, Hitching, Axles and Running Gear 10 01-10-2008 07:26 AM
Tongue Weight Chester Taje Towing, Hitching, Axles and Running Gear 26 07-03-2007 10:59 PM
Tongue weight Jana J Towing, Hitching, Axles and Running Gear 20 05-31-2006 09:44 AM
Tongue Weight Legacy Posts Problem Solving | Owners Helping Owners 1 06-09-2003 12:58 PM
Tongue Weight Chester Taje General Chat 0 01-01-1970 12:00 AM
