tongue weight, dumb question - Page 2 - Fiberglass RV
Old 07-24-2007, 06:32 PM   #21
Brian B-P's Avatar
One more note... the Draw-Tite drawing in Pete's link currently appears in their website on the Determine GTW & TW page.
Perhaps they've had problems with people misinterpreting the original instructions, because it now reads as follows, with specific dimensions:
For heavier tongue weights, place a household scale and a brick that's as thick as the scale three feet apart as shown in Figure 2. Set a length of pipe on each and rest a beam across the pipes. Re-zero the scale to correct for the weight of the beam and pipe. Securely block the trailer wheels. Rest the trailer jack on the beam as shown, one (1) foot from the brick and two (2) feet from the scale.
To obtain the TW, multiply the scale reading by three (3). For greater tongue weights, place the scale and brick four (4) feet apart, rest the jack on the beam three (3) feet from the scale and multiply the scale reading by four (4).
They now say "jack", but as mentioned earlier this won't be quite right if a jack behind the coupler location is used.
Old 07-24-2007, 07:13 PM   #22
Chester Taje's Avatar
I am now sitting on scale.From center(Jack) to scale on one side is 2feet the other side is 1 foot.Scale reads 120 lbs as it sits now.So if you multiply by 3 that comes to 360 lbs.
Old 07-24-2007, 07:34 PM   #23
This whole thing now causes me a problem.I bought my tow vehical to go with a small trailer.Tow rating is 3500lbs.Max hitch weight 350 lbs.
I am sitting at 360 lbs empty.No food --drinks ---water --nothing.This is a delima.
Lesson here is to really do a lot of research.Make sure your choice can do it all.Another thing i found out is that my tow vehical is recommended not to use a equalizer hitch.
I got this vehical with a 3500lb tow rating BUT i never looked into the other stuff.
Old 07-24-2007, 09:59 PM   #24
Trailer: 1976 Trillium 13 ft
The next time I'm at an auction and one of those old warehouse scales comes up for sale, I think I will bid on it. They usually go for about $40-60 bucks and measures wieghs in the range of 1 lb. to 500-1000 lbs. That way all one needs to do is place a pipe/piece of wood on the scale tall enough to support the trailer ball hitch, with the trailer level. And the scale makes a great flower pot holder when not in use.
FRED,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
H. Fred Fuller is offline   Reply With Quote
Old 07-25-2007, 01:00 PM   #25
Brian B-P's Avatar
Thanks for the photo Chester.
Yes, given your distances, you have a 3:1 lever setup, and the 120 lb scale reading means 360 lb tongue weight... except that it is really the jack weight.
If the distances from the jack leg to the trailer axle, and from the coupler (ball centre) to the trailer axle are both known, then the 360 lb can be corrected to the (lower) actual tongue weight. For instance, if the coupler-to-axle is ten feet, and the jack is one foot behind the ball (and so 9 feet from the axle), the actual tongue weight is 9/10 of the 360 lb... which is still 324 lb. For actual number, Chester needs to get out the tape measure...
I still think this is still way more than required for a one-ton trailer. Given the tow vehicle (which I think is quite capable, but not suited to high tongue weight), it seems like something massive really needs to get off the tongue and mount closer to the trailer axle.
I like Fred's warehouse scale idea... if I ran across one like that at that kind of price I'd buy it.
Old 07-25-2007, 01:10 PM   #26
Brian B-P's Avatar
I didn't look into these things before buying my van, either... but then we only decided to tow a travel trailer a year after buying it, so the trailer had to fit the van. Same issue, different order.
I think I'll be saying this a few times: the RAV4 seems quite capable of towing a 13' egg, even if it is very heavily loaded. The tongue weight is very high on this one, as discussed in this thread, due to the large battery set and dual propane tanks. I think it is just too much tongue weight; the equipment choices (particularly the batteries) make good sense, but they just shouldn't be on the tongue given the trailer's configuration. I say fix the trailer, rather than forcing the tow vehicle to carry an unreasonable hitch load.
To add some perspective to this, a full-size GM pickup with Class 4 hitch would be at about 70% of its maximum weight-carrying hitch weight with this trailer, even empty. That's just silly.
Old 07-25-2007, 03:41 PM   #27
Ok--I made some changes to lower tongue weight.I am going to mount my Honda 1000 gen set on the back along with 8 liters of gas.This will be mounted in a angle iron frame.Tongue weight now at 294lbs.I will live with this till i can think of something better.The only other thing off hand is to drop down to one propane tank.
Old 07-25-2007, 04:07 PM   #28
Pete Dumbleton's Avatar
What seems now to be a very long time ago, before I saw the controversial drawing, I did much the same thing without the pipes and using a 4x4 under the coupler, rather than the jack, to get the ratioed weight at the coupler. But that was back when I had a heavy trailer; now I just use a bathroom scale, unratioed, directly under the coupler on a 2x4 or whatever is handy.
Ches, I wouldn't worry about ten pounds, but were I you, I'd weigh everything, including side-to-side, to ensure you get the best balance. And, of course, drive your rig carefully, knowing you are on the edge rather than having a comfortable margin...
Old 07-25-2007, 05:17 PM   #29
Brian B-P's Avatar
I wouldn't obsess about 10 pounds, either... but that's before any cargo!
Also, I'll happily run up to a limit, but in this case the rear of the tug will be sagging (more suspension compression than ideal), because of the hitch weight, which will not help handling. This means either some rear suspension help is appropriate (which we are discussing separately), or - one more time - fix the trailer.
I would rather set up the rig properly, than tiptoe on the edge.
Old 07-25-2007, 07:40 PM   #30
peterh's Avatar
Here's a more-or-less simple solution if you have a local weigh station. Load up your tow vehicle and trailer, then weigh your tow vehicle alone, then the tow vehicle with the trailer without rolling the trailer on the scale, then get the weight on just the trailer axle. The difference between the tow vehicle with and without the trailer is your tongue weight; the weight on the trailer axle plus the tongue weight is the total trailer weight.
--Peter
Old 08-18-2007, 09:45 PM   #31
Ed Calkins's Avatar
Trailer: Bigfoot 21 ft Front Bedroom
Here is some data that relates to this thread. having just purchased a BigFoot 21 that has a design issue with tongue weight (considering the factory just added about 275lbs of ballast weight to the front of this frnt bdrm model) I decided to purchase one of the Sherline tongue weight scales as someone here recommended (good $100. investment in my opinion) and see what weight I had on the tongue. With the water tank full (it is in the front on this model) and the holding tanks empty and our initial provisions stowed aboard (we just got the trailer so more will likely be added as time goes on), the tongue weight was 560 lbs (scale is supposed to be + or - 2%). The weight of the trailer has to be over 5000 lbs, it was almost 4700 lbs as shipped by BigFoot with the options etc. installed but with tanks empty, propane empty, and no battery. So at 560 lbs the tongue weight is OK but marginal in my opinion based on what I read etc. Especially considering some dry camping would result in moving the water at 8lbs per gallon from the front storage tank to the rear holding tanks. I removed the spare from the rear bumper and that increased the tongue weight to about 580 lbs, I added the spare and a few tools to the front outside access storage chamber and that left the final tongue weight at almost 640 lbs (better). I plan to leave the tire up front (in the storage area until I figure another place to mount it). At some point I will add a bike rack to the rear bumper and try to keep the weight of rack and bikes below what the tire and mount weighed. I can now see why they added the ballast weights as these trailers are light in the front and to adjust it by moving axles etc. would be a new trailer design and not feasible. As soon as we get the trailer completely loaded I will weigh the entire package to determine what the tongue weight range should be. Maybe not a neccessary exercise but interesting. Ed
_________________
Ed Calkins is offline   Reply With Quote
Old 08-19-2007, 08:03 AM   #32
Ed Calkins's Avatar
Oops, correction on my tongue weight data in previous post. The water tank is not full, probably half full which is good news as this is likely a more typical condition when towing. The propane tanks (two large 30 lb variety) are close to full. I will fill the water tank and update the tongue weight data. Ed
Old 08-19-2007, 07:21 PM   #33
Ed Calkins's Avatar
Well here goes another attempt to share the data I've collected on my BigFoot 21'FB tongue weight. As indicated in my earlier post I am using the Sherline tongue weight scale. This is a new trailer so it has the ballast weight (275lbs I think) welded into the A-frame and as a cross member near the front of the frame. I used 8 lbs/gal for water weight in the calculation parts of this summary.
With the spare on the rear bumper (cont kit etc. from factory)
Water tank full, propane full, holding tanks empty TW=680 lbs
trailer weight est to be 5190 lbs TW= 13.1%
Water tank emp, propane full, holding tanks empty TW=410 lbs (calc)
trailer weight est to be 4920 lbs TW= 8.3%
With the spare in the front compartment (as I now have it)
Water tank full etc. TW= 760 lbs
trailer weight est to be 5170 lbs TW= 14.7%
Water tank empty etc. TW= 490 lbs (calc)
trailer weight est to be 4900 lbs TW= 10%
If you assume all of the 275 lbs of ballast is tongue weight (most of it
should be) and look at the TW without the ballast added under the above conditions (with the trailer 275lbs lighter of course) the TW would be
in the range of 3% to 10%. It seems you would want to tow this trailer with the water tank full and hopefully with the holding tanks close to empty. I went through this exercise hoping to convince myself I could remove the ballast weights but I think (sadly) that they are needed and I would consider adding them on if you haven't. I met someone in Oregon who traded a 21' FB in on a BF 25' trailer because of being frightened by this swaying situation. I guess I just bought an expensive trailer with an inherent balance design issue -- but I like the trailer and knowing the situation I will manage it. I'm not sure what the implications of the rear bedroom model are but having the water tank in the back I guess makes it the opposite of the front bedroom and you would want to tow with it as empty as possible?? Hope I haven't confused everyone. I do remain a little concerned that if you were on a dry camping trip you might be returning with water tanks and holding tanks in a condition that is not too good for travel (tongue weight)?? Ed
_________________
Old 08-19-2007, 10:28 PM   #34
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft / Dodge 3500HD 4X4 Jake Brake
Thanks Ed, this is important info. Sorry for your issues though.
Old 08-20-2007, 09:56 AM   #35
ddayton's Avatar
Trailer: 2007 Casita 17 ft Spirit Deluxe
Send a message via Yahoo to ddayton
Here's a simple method for weighing your tongue with a bathroom scale.
Pete, best diagram of that method that I have seen.
With this, and other, methods isn't it important that the tongue weight be measured with the trailer at the same level as it is towed? Wouldn't the same trailer, if weighed first nose down, then level and finally nose up, return three different figures?
ddayton is offline   Reply With Quote
Old 08-20-2007, 12:58 PM   #36
Brian B-P's Avatar
Yes, exactly.
Old 08-20-2007, 03:03 PM   #37
Brian's right, the angles do make a difference, and that difference may differ between different trailers depending on construction and loading.
The very best way to do all this stuf is to do it like it goes down the road. However, as long as you have it all set up to weigh, try all three positions to see how they differ. If all your weight inside is low, they won't differ as much as if they were high, because one part of the weight change is the center of gravity (COG) and the higher it is, the more it will move for the same angle.
Likewise, when driving, the trailer and tow vehicle weights will be moving forward or back as the road goes down or up, respectively.
For an extreme example, picture your tow vehicle on a two-platform scale, with the front platform gradually rising. Eventually, you would have 99.44% of the weight on the rear.... Same holds true for coupler vs axle weight when the trailer is off-level. However, I should point out that all this weight transfer is relatively negligible at the shallow angles, presuming COG is also in line (A roof a/c would make some difference, for example).
Keeping the going-out and coming-back weights in mind is also a good thing. My old Jayco had the LP and fresh tanks waaaay front of the axle, with the food storage over the axle. As my trip progressed, the LP left and the fresh water and food moved to the gray and black tanks which were behind the axle. I was aware of the theoretical transfer of weight, but never bothered to measure it because I didn't perceive it on the road (Only had ten gallons of fresh and hardly used much LP, so apparently not enough weight was transferred to make a noticeable difference in handling).
weighing, weight
Dumb question: Tiki torches HustonFamily General Chat 9 07-06-2008 11:05 AM
Dumb Electrical Question Bob H Problem Solving | Owners Helping Owners 2 12-25-2006 06:10 PM
Dumb question re: fiberglass Daisy Problem Solving | Owners Helping Owners 7 05-19-2006 08:32 AM
Dumb electric question Legacy Posts Problem Solving | Owners Helping Owners 14 02-09-2003 06:55 PM
Dumb Question Legacy Posts Care and Feeding of Molded Fiberglass Trailers 13 10-05-2002 09:08 AM
