Top window Removal/Rock Guard - Fiberglass RV
Old 07-08-2016, 07:16 PM   #1
Trailer: Trillium 1300
Hello all - it's been awhile since I've been on - we have moved on to replacing broken glass panes in two of the windows. The top back window does not seem to come out once the screws are removed. The others come out fairly easily lifting up and out but the top doesn't seem to have the room to lift it out - any suggestions? We don't want to take the whole window unit out - if it can't come out, any thoughts on replacing it without using the rubber seal and just siliconing the heck out of it then pushing the new glass piece in to position?
Also, any suggestions for replacing the rock guard framing? The metal framing is broken on both sides right where the arms would slide - can you buy this framing anywhere?
Thanks for the help! Cheers!
littlemisspippy is offline   Reply With Quote
Old 07-11-2016, 07:22 AM   #2
stefman's Avatar
Trailer: 76 Trillium 1300
Waterloo, Ontario
I just had both my back side window panes out of my 76 Trillium for tinting. Yes, the top ones did not want to come out. I had to ease (bend) the aluminum drip edge of the upper frame up, at one end, in order to gain enough clearance. I did the back top corner of each window. I used vice grips and two little pieces of metal to minimize the damage to the aluminum. I only had to ease (bend) it up about 1/4 of an inch and then I was able to wriggle the window past the rock hard seals.
(NOTE - You must be careful not to bend too fat as you might break the aluminum drip edge. Once you get the window out, you can ease (bend) the aluminum back into place so that it is hardly noticeable. )
Once the upper frame for the top glass was out I could clearly see what the problem was. The upper frame piece for the top glass is a little too long on both ends. It does not need to extend 1/4 inch past the side glass aluminum channels. I just used a dremel to shorten them up a bit. It's easy to play with this once the glass is out and you reassemble the frame. GET NEW RUBBER from the glass company. They should have it. It makes putting the glass in the frame 1000 times easier. You could get the glass company to put the glass in the frame for you but then fitment of the frame to the window is harder when the glass in in. I hope this kind of makes sense. I do not claim to be an expert and I would not want you to damage your trailer. This is how I did it.
As far as the rock guard goes, if it's the piece I think it is I found that U-channel for the sides of the rock guard at Home Depot. It's not exact but it worked.
stefman is offline   Reply With Quote
Replacing the center section of the front window rock guard Gumpit Problem Solving | Owners Helping Owners 3 12-03-2010 10:12 PM
Replacing Trillium Window Rock Guard Booker B. Problem Solving | Owners Helping Owners 32 04-21-2010 08:15 PM
Boler front window rock guard install RogerH Problem Solving | Owners Helping Owners 12 09-10-2009 10:39 PM
Needed: Front Window Rock Guard Ray and Patty Parsons Classified Archives 0 05-20-2008 12:11 PM
Rock Guard For Window? Chris73 Problem Solving | Owners Helping Owners 9 04-23-2006 09:16 PM
» Virginia Campgrounds
