Torque setting on Lug Nuts - Page 3 - Fiberglass RV
Old 04-21-2015, 06:19 PM   #29
Ian G.'s Avatar
Definitely not silly questions. Remember many took auto shop through school, I went through 2 years additional technical college plus 2 year apprenticeship.
Yes if you apply too much load to a torque wrench in either direction you can damage the calibration, but a click type torque wrench should measure torque in both a clockwise and counter clockwise direction. If you set the torque value and use it to loosen as long as you do not exceed the maximum designed torque for that wrench it should be fine. What you should not do is apply excessive load on the wrench in either direction.
Old 04-21-2015, 06:21 PM   #30
mgellar's Avatar
Trailer: Scamp 16' Oak Deluxe Layout A - "Kiwi"
Maryland
I see this one http://www.amazon.com/Gorilla-Automo.../dp/B0028081GK that I almost bought (someone might have provided a link to it) appears to work in reverse, too. I went with the Sears because of the rubber handle, but then I had to buy and extender as well, and the case it comes in doesn't hold the extender nor is it a fully enclosed case like the Gorilla. It looks like I keep what I got so far and get a breaker bar, or return the sears items and get the Gorilla. The rubber handle was the biggest draw for the Sears - in the end, it cost more with the add-ons, even before the breaker bar.
mgellar is offline   Reply With Quote
Old 04-21-2015, 07:52 PM   #31
IllAnnoy
Tighten 'em 'til they break then back-off an eighth of a turn!
Torque value for wheel nuts Donna D. Towing, Hitching, Axles and Running Gear 28 03-28-2014 05:43 PM
Source: Chrome lug nuts Derek Johnson Modifications, Alterations and Updates 6 05-22-2013 08:36 PM
Tightening hitch/lug nuts Cathi Care and Feeding of Molded Fiberglass Trailers 22 11-18-2012 04:32 PM
Stripped lug and lug nut? FlyboyTJ Problem Solving | Owners Helping Owners 2 07-04-2012 10:55 AM
Lug-nut torque Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 12-16-2002 01:30 PM
