Torque setting on Lug Nuts - Fiberglass RV
Old 07-15-2014, 08:55 PM   #1
papa-t's Avatar
Glade Valley, North Carolina
Just wondering what the recommended torque setting is on Scamp lug nuts. Thanks
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 07-15-2014, 10:21 PM   #2
Depends on what size wheels you have on it.
Trailer Wheel Torque Requirements.
Old 07-16-2014, 07:29 AM   #3
Trailer: Scamp 19
I have 14" rims and use 100 ft. lbs. This is recommended by both Scamp as well as Discount Tires where i fot my tires. I have checked them a couple of times and found only one nut looser than that. Yes I do carry a torque wrench when I travel.
captsteve2002 is offline   Reply With Quote
Old 07-16-2014, 08:22 AM   #4
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Dexter recommends between 90 and 120 ft-lb for 14" and 15" wheels.
Old 07-16-2014, 08:45 AM   #5
papa-t's Avatar
I have been setting at 100 ft. lbs. So, thanks to all.
Old 07-16-2014, 09:24 AM   #6
Trailer: Escape Trailers
Massachusetts
What type of torque wrench?
What type of torque wrench do you recommend?
Stretcher is offline   Reply With Quote
Old 07-16-2014, 09:56 AM   #7
frank_a's Avatar
Trailer: 2012 ParkLiner #006
I've been playing with cars and trucks for years, and generally just tighten the heck out of lug nuts on steel wheels. Then I check them. And check again. Ad nauseum, especially trailers. Disc brakes with aluminum wheels I am much carefuller with, and will use one of my torque wrenches and torque to spec.
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 07-16-2014, 10:40 AM   #8
Trailer: Scamp 19
I have a good quality torque wrench, Snap-On, and have bought a Harbor Freight one to carry in the trailer. The HF one is off a bit, there is 2-3 ft. lbs diffence between the two. I check the HF one when ever I'm home.
Old 07-16-2014, 10:44 AM   #9
Steve L.'s Avatar
Wow. I have all sorts of things to say about this but this really isn't the forum. In general I subscribe to the "you get what you pay for" philosophy, also known by what I call ABHF (Anything But Harbor Fright).
I have a bunch of them and I try to use the particular wrench where the desired torque I'm looking for is in the middle of the wrench's range. It's thought that's where most wrenches are most accurate.
Old 07-16-2014, 10:59 AM   #10
frank_a's Avatar
I have a quality Craftsmen torque wrench, NOT digital, but a clicker type. Best way to keep a torque wrench honest is to ALWAYS turn it to zero after any use.
Frank
2012 ParkLiner #006
Old 04-20-2015, 07:50 AM   #11
mgellar's Avatar
Trailer: Scamp 16' Oak Deluxe Layout A - "Kiwi"
Maryland
Hi,
I'm trying to get clarification on the lug nut torque setting for my new Scamp 16' with 13" wheels. The link to the chart shows a much lower setting than others say they use. And in general, is there someone or way to ask Scamp questions like these if they're not on their site? So far, Alan has been the only one I've asked questions to, but I don't feel that's the best source.
mgellar is offline   Reply With Quote
Old 04-20-2015, 08:02 AM   #12
Ian G.'s Avatar
Lug nut torque should be based on the wheel stud size NOT the rim size. For 1/2" wheel studs the recommended torque is 90-120.
Here is a far better torque spec chart http://www.countrytrailer.com/uploads/TorqueSpc.pdf
Old 04-20-2015, 09:02 AM   #13
mgellar's Avatar
Maryland
Thanks. I guess that's the stud or bolt vs the nut.
Old 04-20-2015, 10:20 AM   #14
mgellar's Avatar
Maryland
Yes, the studs are 1/2". Thanks!
Torque value for wheel nuts Donna D. Towing, Hitching, Axles and Running Gear 28 03-28-2014 05:43 PM
Source: Chrome lug nuts Derek Johnson Modifications, Alterations and Updates 6 05-22-2013 08:36 PM
Tightening hitch/lug nuts Cathi Care and Feeding of Molded Fiberglass Trailers 22 11-18-2012 04:32 PM
Stripped lug and lug nut? FlyboyTJ Problem Solving | Owners Helping Owners 2 07-04-2012 10:55 AM
Lug-nut torque Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 12-16-2002 01:30 PM
