Total plywood replacement? - Page 2 - Fiberglass RV
Old 03-12-2008, 05:36 AM   #15
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I wonder if it wouldn't help to make the template of the floor pieces before you ripped out the flooring. Depends on how intact you think the floor will be after removal.
I vote for exterior plywood rather than MDF.
If you don't have a fiberglass bottom, (the bottom of the floor is exposed to the outside) I wonder if it wouldn't be a good idea to laminate a layer of light gauge fiberglass woven material to the bottom before putting the new flooring in place. Even rolling on a layer of resin alone would add protection. Might not hurt to protect the inside as well.
Without adult supervision...
Also,
Old 03-12-2008, 11:58 AM   #16
Pete Dumbleton's Avatar
Scamp coats both sides of the flooring with resin before installing. Not sure if a full FG treatment is good because moisture that does come from above would be trapped. Most leak problems are from above (appliance, window or belly leak) rather than spray from below.
I personally don't think it makes much difference whether the flooring is 'real' plywood of x layers, MDF or OSB, as long as it's exterior grade (for the glue) and not particle board. All of them have been known to rot. The trick is to keep them dry in the first place.
Old 03-12-2008, 12:16 PM   #17
Trailer: 13 ft Perris Pacer
Precisely.
Angelo F. is offline   Reply With Quote
Old 03-12-2008, 12:19 PM   #18
Coach George Jessup's Avatar
Send a message via MSN to Coach George Jessup
...If you don't have a fiberglass bottom, (the bottom of the floor is exposed to the outside) I wonder if it wouldn't be a good idea to laminate a layer of light gauge fiberglass woven material to the bottom before putting the new flooring in place. Even rolling on a layer of resin alone would add protection. Might not hurt to protect the inside as well.
IMHO a layer of roll on truck bed liner would be better but got to admit I do not know which would adhere better. What ever you use you want it to be something that does not allow water or air to get between it and the wood.
Coach George Jessup is offline   Reply With Quote
Old 03-12-2008, 12:34 PM   #19
Just kind of wondering out loud if a couple coats of marine hull paint would be a good thing to put on wood that's exposed to the elements.
Old 03-12-2008, 12:59 PM   #20
that was similar to Jane P's offered solution on the topic Visit Shower Side Bathroom Door. Her comments are worth reading!
Old 03-12-2008, 01:01 PM   #21
Steve L.'s Avatar
All valid points but I'm more from the trying to keep it out school rather than the giving it a path out school. I'd resin the top, bottom and edges.
Also,
Old 03-12-2008, 01:50 PM   #22
brady hansen's Avatar
Trailer: 1973 Boler
Unhappy
I think paint would add a layer of protection-but would eventually get blasted off. Resin, glass, or undercout could probably withstand the road damage much longer.
brady hansen is offline   Reply With Quote
Old 03-12-2008, 02:07 PM   #23
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft
I have a houseboat and as you can imagine moisture and plywood rot is always on my mind. The boat I bought had already lost some plywood.
What I have found is that the new plywood itself needs to be protected from rot first - primer. Then a coating put over it. Fiberglass over plywood by itself has a tendency to allow moisture to get between the glass and the wood, then rot. A product called CPES is the best I've found. (one of those an ounce of prevention things.)
What is CPES Primer?
Clear Penetrating Epoxy Sealer (CPES) consists of a tough, flexible resin system in a solvent blend which aids in the restoration of rotted or deteriorated wood and the protection of new wood. The Epoxy Resin system chemically adheres to the wood fibers and significantly strengthens them while allowing for normal expansion and contraction.CPES is effective because of the special blend of solvents that allow it to migrate into the wood fibers and into the cellulose of the wood. Impregnation of the wood with the Clear Penetrating Epoxy Sealer changes the cellulose of the wood (which the bacteria and fungi find easily digestible) into epoxy impregnated cellulose which resists the fungi, while reinforcing the wood, and accomplishing restoration.
CPES is a two-part product. Mixes 1:1 equal parts of A and B by volume. Apply with brush, roller or immersion. Will cure down to 50 F. Also called MultiWoodPrime, CPES makes an excellent paint and varnish primer as it chemically bonds the finish deep inside the wood grain.
More info...
http://www.epoxywoodrestoration.ca/price7_050.htm
Here are some tests showing the benefits:
http://www.rotdoctor.com/test/polytest/polytest.html
One place to buy
http://www.star-distributing.com/smith/cpeswhy.html
I hope this helps.
Old 03-12-2008, 02:07 PM   #24
Trailer: 82 Burro 13 ft
that rubberized roofing tar repair stuff might work good... you can brush it on...
--- steven
edit- on second thought, that CPES stuff looks much better...
steven jones is offline   Reply With Quote
Old 03-12-2008, 02:42 PM   #25
I just found this study. (Y'all got me wondering). On soft wood like plywood, CPES works great. On Oak it seams everything has problems. Anyway, this is a good read on how well finishes hold up on new wood exposed to UV after finishing. I know ours is not exposed to UV, but hey, what the heck. It is really testing this stuff.
http://www.mar-k.com/wood_finish_testing_ii.html
Old 03-12-2008, 06:51 PM   #26
If I felt I needed more protection on the bottom, I would just spray on automotive undercoat.
BTW, it makes a lot of sense to me that MDF and OSB would soak up more resin than plywood does because there's a lot more end grain in the first two and that's where wood really sucks up liquids.
Old 03-12-2008, 09:04 PM   #27
Trailer: Fiber Stream
Talking
That's what I did with my '71 Compact Jr.
Old 03-13-2008, 09:13 PM   #28
Rob S.'s Avatar
Trailer: 1980 Bolar 1700
Massachusetts
Hey All,
Coming into this discussion late. As mentioned before, do not use MDF. It is so much heavier (96lbs. 3/4"-4x8) and does not have the structural integrety needed. What I would use with an exposed undeside is MDO Ply (71lbs. 3/4"-4x8). This is the same exterior grade plywood that is used in the signage industry and what most of the blue highway signs for shops, resorts and camping area type signs are made with. Is is long term exterior grade and faced on both sides with a thin resin paper overlay. Takes paint really well as well as adhesive vinyl. Rather than a heavy undercoating you might consider buying a role of 3M vinyl and adhearing it to the ply and then installing it. This would give you a watertight underside without the weight and the vinyl comes with a 3-7 year warrenty and that is expossed to full sun and elements which the underside won't be.
http://www.boulterplywood.com/Exteri...ePlywood_4.htm
Rob
Rob S. is offline   Reply With Quote
total makeover-Would you do it again Kent I Care and Feeding of Molded Fiberglass Trailers 30 01-21-2017 06:40 AM
Plywood floor replacement supplies Mike Shackelford Problem Solving | Owners Helping Owners 3 10-08-2009 07:17 PM
Floor replacement Options - OSB vs Plywood. Oliver P Problem Solving | Owners Helping Owners 11 08-11-2009 08:34 PM
Plywood Floor Replacement 72 Boler Annie T Problem Solving | Owners Helping Owners 5 07-24-2007 10:19 PM
plywood edging Peggy Problem Solving | Owners Helping Owners 8 07-09-2007 01:04 PM
