Towing - Fiberglass RV
Old 11-06-2015, 08:50 PM   #1
Towing
Recently purchased a 79-17 foot Boler and would like to know should I have any problems towing it with a 07 Silverado half ton.
Ken Storgard is offline   Reply With Quote
Old 11-06-2015, 09:02 PM   #2
One would think not...BUT what does your owners manual say about towing for your vehicle, meaning maximum towing and tongue weight. Some 17'ers get north of 3500 lbs. fully loaded. Here's a list of actual weights.
Trailer Weights in the Real World
Old 11-06-2015, 09:40 PM   #3
Pam Garlow's Avatar
Trailer: U-Haul 1985
Yep, the first step is to check your truck manual which will give you the tow rating. And if the rating is followed by ** asterics, then find out what they refer to. Usually it will say **when properly equipped (meaning brakes on the trailer and a tow package on the vehicle).
Good for you to have a big boler! Not so many of them around. Be sure to post photos, we'd love to see them
Old 11-06-2015, 11:10 PM   #4
IllAnnoy
I had over a hundred Chevy trucks in fleet for many years, and while they did keep me in paychecks, I see no reason not to trust yours for towing, provided you've maintained it.
BTW...You don't mention what gear, what engine, what configuration (regular cab to crew cab) or what wheel base, tires or payload package.
Old 11-08-2015, 06:28 PM   #5
Thanks for the replies. the truck is your standard extended cab with 3 speed with over drive automatic 4/8 V8. The trailer is approx. 2200. The owner s manual says maximum 7000. It has the tow/haul mode.
Towing Definitions-Understanding Towing weight terms cpaharley2008 Towing, Hitching, Axles and Running Gear 49 06-19-2019 02:27 PM
Towing like you're not even towing? swoosh Towing, Hitching, Axles and Running Gear 18 07-30-2015 09:18 AM
Liability and overweight towing (split from Towing 13' Scamp...) Bob Miller Towing, Hitching, Axles and Running Gear 88 04-18-2014 05:10 PM
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 02:04 AM
