Towing Hitch - Fiberglass RV
Old 05-14-2012, 12:49 AM   #1
Trailer: 1984 13ft. Scamp
Towing Hitch
I just bought a 13ft. Scamp and need a hitch for my 1993 Toyota 4Runner. Could someone give me advice on that? Also, being female, I can't lift a lot of weight. Is there some type of battery operated lift thingy? I can hear you laughing
Sandy
Sandy Sue is offline   Reply With Quote
Old 05-14-2012, 01:19 AM   #2
Saskatchewan
to ways you can do it, get the factory toyota one and the wiring for it, or get a quality reese one installed.
What are you lifting? the tongue jack on the trailer should do all the lifting for you with a crank of the handle, if not, they are easy to find and they make power ones too.
Orcus79 is offline   Reply With Quote
Old 05-14-2012, 09:34 AM   #3
Welcome Sandra! being female I am not laughing and get your concern! As suggested if you have a tongue jack with a wheel on it you should never have to lift the trailer yourself. If your jack crank handle is hard to turn it may just need some lubrication. More often that not I do the the hook ups myself and I have never had to manually lifted the trailer tongue. With practice you will get good at getting the ball right under the tongue - if you miss it by an inch you should be able to push it over the ball using the jack wheel with little effort. There also some hitching aids that would be a lot cheaper than the electric jack that can help you get the ball right under the trailers hitch.
Old 05-14-2012, 09:52 AM   #4
MC1
MC1's Avatar
X2.... The Toy receiver is noted for it's cheap, lame design and construction. Aftermarket is the way to go. Class III is just a few bucks more and has much more beef then the II's.
Old 05-14-2012, 10:11 AM   #5
Perry J's Avatar
Trailer: 16' Casita
The best and least expensive place for a hitch install is U-haul.
John
Old 05-14-2012, 12:28 PM   #6
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Don't buy a Curt brand hitch. Go to a U haul hitch center and have them do your install. I love Toyota's but the Toyota hitch will be very pricey.
Old 05-14-2012, 12:45 PM   #7
I agree with Perry & Greg there is nothing at all wrong with going to U-Haul have had good service from their hitch department and there hitch has worked/lasted fine for me.
Old 05-14-2012, 05:49 PM   #8
Towing Hitch
Wow, I can't thank you enough. I'm learning
Sandy
Old 05-14-2012, 06:20 PM   #9
Mike Magee's Avatar
Trailer: Li'l Hauley
If your jack is too hard to crank, they do make electric replacement jacks (for maybe $150?). But the 13's tongue is usually fairly light, so I doubt you will have a hard time cranking the manual one.
How to prepare Tofu
Step 2: grill some meat
Old 05-14-2012, 07:20 PM   #10
Perry J's Avatar
Trailer: 16' Casita
I became bored after I retired and went to work for a Toyta dealership.
I don't think we ever installed a factory hitch.
Hitch installation was farmed out to a small RV dealer nearby or went to U-Haul.
The Toyota store owner also owned a good portion of the Honda store across the street and I worked their also.
All of the Honda hitch installations were also farmed out.
John
Old 05-14-2012, 09:18 PM   #11
Greg H's Avatar
Indiana
Perry, what I meant was that if Toyota has a hitch it would be way expensive. I don't know who puts the hitches on Toyota trucks but I do know if it says Toyota it would be expensive. When I couldn't locate a hitch for my Toyota P/U I went to a dealer and priced a chrome step bumper (the same bumper that used to be $99.00) was priced somewhere between $3and $400.00.
Old 05-14-2012, 10:21 PM   #12
Trailer: 1975 Triple E TM10 Surfside
Saskatchewan
I just recently had uhaul install a hitch on my ford escape. Ford wanted almost $1000 and uhaul did it for just a little over $250 lifetime warranty on the hitch two year on the wiring.
sherad is offline   Reply With Quote
Old 05-14-2012, 10:23 PM   #13
Perry J's Avatar
Trailer: 16' Casita
I knew what you meant Greg.
I just wanted to add to your comment.
If you have a hitch installed at the Dealership it's no better than a U-haul hitch and 2 or 3 times more.
John
Old 05-15-2012, 06:09 AM   #14
Trailer: scamp 13
actualy the problem with the 13foots jack is the gear ratio. its way to easy . takes about a millon revolutions to raise and lower it.
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
I have a Hitch now! melissab General Chat 11 06-20-2011 02:05 PM
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
How Not To Use Your Hitch Patrick M. Jokes, Stories & Tall Tales 4 04-20-2008 02:32 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 03:05 PM
