One factor to note about front wheel drive (FWD) versus rear (RWD)
While every FWD vehicle will be significantly front-heavy (at least when not carrying significant load), RWD vehicles may be anything from extremely front-heavy to significantly rear-heavy, even empty. This makes a huge difference to traction. In most forms of motorsport where the design is not closely related to a stock vehicle, RWD (or all-wheel-drive) is preferred, but they have
appropriate weight distribution.
And as for controlling a FWD car...
Automatic transmissions can be death to vehicle control. It can be very handy to be able to push the clutch pedal and remove the drivetrain from the handling equation, at least momentarily. Even with an automatic, appropriate technique can help. Roger, spectate at an
SCCA Rally event some time, and see what FWD can
really do.
Many years ago, I would regularly compete in solo motorsport events run on tracks plowed out of the snow on frozen lakes, usually in a stock FWD car. I was always pushing the limit of control (remember this is a closed and controlled event, not a public street...) and I rarely found myself in an unrecoverable situation. I also entered every high-speed turn (commonly 80 km/h or 50 mph entry speeds) with the tail hung out in an oversteering drift. A trailer would complicate that, of course, but it would with RWD too!
By the way, in that form of competition on ice, the classes were determined by the type of tire. There were a couple of studded classes, but no one ever mentioned the idea of using chains...
