Towing questions - Fiberglass RV
Old 05-30-2007, 05:50 AM   #1
Trailer: Casita 2004 Spirit Deluxe
New to the forum and I am getting my 04 Casita 17' SD tomorrow. Tug is 97 Nissan Pathfinder 4WD 5 sp with 3500 tow cap. and a 5000 # hitch. Just replaced my clutch. Any recommendations such as optional oil cooler? I am also thinking of a weight distributing hitch as the tongue weight seems to load the rear of the truck.
Don Barnes is offline   Reply With Quote
Old 05-30-2007, 07:37 AM   #2
Roger H's Avatar
Hi Don! Welcome to the Forums!
I split your post into a new thread as I think it is significant, and deserves to stand alone.
In response, usually transmission coolers are required on automatic transmissions in response to heat build up caused by plate/band slippage (or some such thing... automatic transmissions work by magic, as far as I actually understand them). Manual transmissions are just a gear box and don't require any additional cooling (generally speaking). I'd expect your Pathfinder's tranny will do just fine. The heat buildup and expendable parts on a manual transmission are the clutch plates.
I'd suggest that the appropriately-sized weight distributing hitch would be in order. I'd also recommend that you use some sort of sway control; whatever is appropriate for the tongue weight of the Casita.
Best of luck!
Roger
Questions about towing Jennifer Gonzalez Towing, Hitching, Axles and Running Gear 32 08-16-2010 06:36 PM
Basic Camper Towing Questions Jason Rutten Towing, Hitching, Axles and Running Gear 8 03-06-2010 07:00 AM
More Subaru Forester Towing Questions Michelle A Towing, Hitching, Axles and Running Gear 12 04-04-2009 10:18 PM
Replacement windows, questions, questions. CliveAlive Modifications, Alterations and Updates 4 07-13-2006 07:32 AM
Newbie questions on towing/repair Sharyl Allender General Chat 23 05-28-2006 11:03 PM
