TRAILER BALL SIZE ??? - Fiberglass RV
Old 06-06-2006, 10:30 PM   #1
Dan Quinn's Avatar
im haveing a hard time figureing out the size to use it says nothing anywere i tried 1 7/8 and 2 inch and it just dont seem wright what size is everyone else useing on there fg trailers..
Dan
Dan Quinn is offline   Reply With Quote
Old 06-06-2006, 10:46 PM   #2
Pete Dumbleton's Avatar
My Scamp 13' uses 1 7/8" and I believe the Scamp 16/19 uses 2". I also believe all the Casitas use 2" also, so likely that's what yours should be.
On the underside of most couplers, there is an adjusting nut to move the clamp mechanism in and out -- Maybe yours just needs adjusting (a previous owner may have tried to use a smaller ball than 2" and adjusted it too tight).
Old 06-07-2006, 01:50 PM   #3
Brian B-P's Avatar
My Boler B1700 uses a 2" ball/coupler. I have yet to see a coupler which did not have the ball size stamped into it (along with the weight capacity, etc), but layers of paint can make it hard to read. I didn't see the information on mine at first - I'd suggest another look, and maybe even some paint stripping.
HELP! At trailer hitch place, what size ball do I need? joy mccalla Towing, Hitching, Axles and Running Gear 5 01-18-2010 09:48 PM
Wrong size hitch ball Kevin K General Chat 10 06-23-2009 04:09 AM
1976 Trillium 13' - ball size? Sahm J Towing, Hitching, Axles and Running Gear 8 10-21-2008 10:40 AM
Need some help, ball size & towing Arline Lovell Towing, Hitching, Axles and Running Gear 10 06-08-2008 02:59 PM
» Trailer Showcase
Lumpy
dart4tony
Casita
GlendaW
