Trailer lights - Fiberglass RV
Old 08-13-2007, 09:37 PM   #1
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
When I picked up the trailer all but one turn light was working. Now nothing is.
I took off the light covers. Each light has a place for two bulbs. But there were only bulbs in one of each, and those were two-wire bulbs. I can't find a number on the bulbs. The bulbs appear intact. Do I stay with the two-wire bulbs or put one in each socket? (I tried moving the one bulb to the other socket and it still did not do anything.)
So: how do I go about troubleshooting? I know the lights are working coming from the car wiring as that connector has lights that blink to show you they are working. Then there is an adapter from the car plug (which is flat, with the 3/1 connector, to the trailer plug adapter (round to flat.) That was new in May.
Bobbie
Old 08-13-2007, 09:42 PM   #2
Trailer: Eggless at the moment
Is there a fuse somewhere? That's what it sounds like to me.
Bonnie
Plotting my next adventures...
Bonnie is offline   Reply With Quote
Old 08-13-2007, 09:46 PM   #3
If there is a fuse I would not know where to look.
I have not seen one. (And I know it isn't in the TV.)
Bobbie
Old 08-13-2007, 11:20 PM   #4
Trailer: Hunter Compact II
Send a message via Yahoo to mikecontos
You may need all bulbs installed to make a complete circuit. No bulbs may be causing an "open" thus interrupting the flow of electrical current. I would take the bulb that you have to an auto parts store and I just about gaurantee that they will be able to match it. If when all bulbs are installed the lights still dont work you may have a wiring issue. This is where my expertise is limited to tracing out each wire to make sure there are no breaks or disconnects. Look for in line fuses as well, my Hunter had one hidden beneath the forward bench where all of the wiring comes in.
Hope this helps...GOOD LUCK
Mike
mikecontos is offline   Reply With Quote
Old 08-14-2007, 06:27 AM   #5
Trailer: Bigfoot 20 ft 5th Wheel
I've had this problem with my rear signal and brake lights. They worked fine when I got the trailer but then quit. I found the bulb sockets were tarnished and a few were corroded lightly causing an intermittent connection. I used a .45 caliber brass brush in a drill to buff them up inside for a good connection. They seem fine now.
Be gentle when using the drill and brush though, you don't want to damage the socket. If you don't have any barrel brushes I think you could easily do it by hand with a bit of dowel wrapped in steel wool.
scott fraser is offline   Reply With Quote
Old 08-14-2007, 08:08 AM   #6
I'd suggest using Dielectric grease in the sockets, available at any auto parts/hardware store... for less than $5.
Old 08-14-2007, 08:17 AM   #7
Interesting stuff Donna, I'd never heard of it but will definitely apply some now that I've got the sockets cleaned up.
Thanks!
Old 08-14-2007, 09:09 AM   #8
There is no sign of corrosion in the sockets. Also, the lights WERE working three months ago when I parked the trailer, except for one turn light. So I doubt it is either the lack of bulbs or corrosion, but I'll check.
I woke up this morning thinking, Hey, the trailer wasn't actually coupled to the car; maybe I didn't have a ground. Hitched it up and tried it, still no lights. So that wasn't it. It occurs to me it could be the adapter. I'm going to see if I can find a replacement for that and try it again. I think if I take the old one up to Napa and ask they can check it, though. I'm also going to get a test light. And of course look for a fuse.
This puts a hitch in my plans to get the wheel bearings repacked today- I don't dare drive to the repair place without either a registration OR lights, so I will have to wait to either fix the lights or get my 3 day pass (from Wed-Fri) for moving the trailer through Washington and Oregon. I'm going to try to call the Cal. DMV this morning, though.
Bobbie
Old 08-14-2007, 04:04 PM   #9
Okay, so I went to Napa, got a nice helpful guy to look at the adapter. He told me it is supposed to (legally required to) be mounted on the TV. (The Napa guy who sold it to me didn't say so.) He also tested it and decided it works if grounded properly, but the right turn didn't work (which it didn't on the maiden trip.) So he suggested wiring a new four way connector in instead of the bad one.
I came home and did that. It still doesn't work. So now I don't know if it is the adapter or the trailer; and if the trailer, what the heck happened between now and May. So I called Les Schwab, who are going to repack the wheel bearings, and asked if they could look at it. They can, as long as it is something they can test or visible.
What I do if it still does not work, I have NO idea.
In the meantime, I'm off to the DOL to get a trip permit, since a 45 minute call to the Cal. DMV this morning yielded only the information that my registration is in the system, and probably will take three more weeks to finish processing. Oh, and the extra $19? $17 for a fee their automatic fee calculator left off, and a $2 penalty for not including the fee that their automatic online fee calculator left off.
Whose idea was this trailer, anyway???
Bobbie
Old 08-14-2007, 05:50 PM   #10
Brian B-P's Avatar
Certainly not the California DMV's... they seem determined to keep it off the road!
Old 08-14-2007, 05:55 PM   #11
Brian B-P's Avatar
...the lights WERE working three months ago when I parked the trailer, except for one turn light. So I doubt it is either the lack of bulbs or ...
I agree. The bulbs are wired in parallel, meaning their + contacts are all connected to the +12V source, and their other contacts are all connected to the return side of the circuit, so the current for any one of them doesn't pass through the others. That way, all bulbs work on 12V (if two were connected in series, they would need to be designed for 6V each... it isn't done that way in vehicles).
Often the wires are connected in a chain from one socket to the next, so a bad connection at one kills all the rest further down the chain. At each socket there's a fork in the wiring... one way into the that socket's bulb, the other way on to the next bulb. Break the wire connection coming into the fork, and there's no power for either way.
That's a more likely source of the problem. The return (often called "ground", normally white-insulated wire) side is the most likely culprit in this type of problem, because tail and left and right and marker lights can all be connected in the same chain. I lost most of my clearance lights for a while when I touched one of them...
Old 08-14-2007, 06:29 PM   #12
Roy in TO's Avatar
There are simple testers you can buy to show if your connector is working.
Alternatively you probably know someone with a trailer (boat & utility included) that you could test your Tow Vehicle connection with.
Old 08-14-2007, 07:20 PM   #13
The four way connector is working- coming off the TV; it has a built-in tester.
Then it goes to the 7 way connector- that's what I don't know if is working. I bought a tester but I think it is the wrong kind and I don't know where to connect it anyway. Somebody help?
The guy at Les Schwab is going to look at it, but he suggested maybe a mouse ate a wire!
(I don't think so.)
I don't think I've knocked any wires loose but maybe I'll try all the connectors on white wires and see if anything helps. For one thing, there are wires (not white) coming out in the light boxes (I don't know what you call those, the place the bulbs go) that look like they ground to a screw but it could be either of the top screws and I don't know if it matters.
My back-up plan if I can't fix this is to postpone my departure, order wireless magnetic tow lights from U-haul, and not leave until they arrive (I want some for my boat trailer anyway so even after I fix the trailer I could still use them. I wish I'd done that a week ago, though.) The reason I didn't check the lights before is that they WERE working, and I didn't do the wheel bearings because I wanted them on the three-day trip pass.
Bobbie
Old 08-14-2007, 08:07 PM   #14
Trailer: 94 Casita 16 ft
When I first started reading this post, I would've bet you a nickel that it was a bad ground. I'm not ruling that out, but after reading that you're going from a flat 4 to a seven pin, I'd say that there's an issue with that as well.
The first thing I usually do when checking lights is "jiggle stuff". Hook up, start your vehicle, turn on your running lights and 4-ways. Remove the taillight cover, and jiggle the bulbs. Take them out, put them in, turn them, and wiggle them (BTW, I'd bet they're 1157's). Next, with everything still running, jiggle the connectors. Unplug/replug them a few times.
Lastly, if this hasn't worked, turn off your vehicle, and remove the cover from your 7-pin connector. Inside you should see that the wires are mounted inside little holes, and held in place with little set screws. Get yourself a small screwdriver, and loosen then tighten those little screws.
If all this 'jigglin' doesn't help, then I'd bet your 7-pin is wired wrong. Somewhere on here is a link to the industry standard wiring diagram for the 7-pin harness.
Or you could let the guy at Les Schwab look at it.
Paul from NWOnt is offline   Reply With Quote
lighting, lights
More lights in my trailer Donna D. Jokes, Stories & Tall Tales 1 07-23-2009 12:11 PM
Trailer Lights - no blinkers?? Tim M Problem Solving | Owners Helping Owners 3 06-24-2009 09:41 AM
Escape Trailer External Lights Thane Modifications, Alterations and Updates 1 10-13-2008 04:06 PM
Trailer Running Lights Darwin Maring Problem Solving | Owners Helping Owners 0 12-25-2006 06:52 PM
Wireless Trailer Lights Pete Dumbleton Problem Solving | Owners Helping Owners 15 11-07-2006 11:52 PM
