Trailer skirts?? - Fiberglass RV
Old 01-07-2019, 05:04 PM   #1
Trailer: Casita 2018 Independence Dlx
Trailer skirts??
Looking for an easy to use "trailer skirt" to use in cold weather to help keep the Casita underbelly warm and the plumbing functional, while camping in cold weather. Any thoughts?
Fred762 is offline   Reply With Quote
Old 01-07-2019, 09:05 PM   #2
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
Try using bales of hay
Old 01-07-2019, 09:54 PM   #3
Bales of hay or straw banked up with snow
Both make excellent insulators
steve dunham is online now   Reply With Quote
Old 01-08-2019, 07:32 AM   #4
Search youtube for Keep your daydream winter camping.
They do a nice recap of skirting and other issues for winter camping.
thrifty bill is online now   Reply With Quote
Old 01-08-2019, 07:33 AM   #5
I agree straw is best, but it hardly qualifies as “easy to use.” It would take a couple of pick-up loads. Best for a semi-permanent set-up.
Fred, how do you plan to use this? What kind of cold weather camping are you planning?
Old 01-08-2019, 08:38 AM   #6
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
A lot will depend on the temperatures you are in. If you are in temperatures where it rarely warms above freezing during the day, there will be no easy to use solution unless you had a method of pumping heat underneath too. Anything with good insulating value, like the straw mentioned above, is not that easy to use, but fine for a permanent setup. Even with good insulation a bit of heat is needed to keep things from freezing underneath. You might get enough transferring through the floor, but that is not enough in real cold weather.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 01-08-2019, 04:09 PM   #7
straw
Naah, we're looking for something to take on and off while camping, moving the TT, etc. straw wd not wrk
Old 01-08-2019, 05:06 PM   #8
I have a friend that's full-timing in her trailer in Canada. Land of cold and snow. She's not in an all-molded-towable though. She IS a traveler, but will be staying in one place for at least a month. She bought and installed RV skirting from this company. She says they have stellar customer service and they give free estimates:
Trailer Skirting for Your RV by Kimbers Creations
Old 01-08-2019, 07:38 PM   #9
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I wonder if several of the light weight swimming pool air mattresses, wedged upon their sides would be a possibility, (you would want a small aircompressor though).
Dave & Paula
Old 01-08-2019, 08:50 PM   #10
Dave & Paula
Good thinking outside the box.
There is a problem with your suggestion. The tubes of air are too big to provide any insulation. Good insulation is generally comprised of very small areas of air containment. This prevents eddy currents with transfers heat between each side of the air mattress so that both sides are equally cold.
Old 01-09-2019, 12:24 AM   #11
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Might not be much for insulation but would make a contained area on the underside keeping the wind from blowing through. Add a drop light and that may be all that it takes to keep the temp up enough for what the OP is looking for. Sure would be cheap to try out....and roll up small for storage .
Old 01-09-2019, 12:25 PM   #12
Keeping the wind out might help. However you can accomplish that with a small roll of 4mil plastic.
Old 01-09-2019, 12:30 PM   #13
Any stopping air flow is even more important than insulating, because if the heat easily escapes, the effectiveness of the insulation does not really matter.
2017 Escape 5.0 TA
Old 01-09-2019, 03:06 PM   #14
air mattresses
Good ideas..the 4 mil plastic sounds good..not take up too much space either..Hmmmmmmmmmmmmmmmm
Fender Skirts campfrugal Problem Solving | Owners Helping Owners 1 04-05-2011 08:56 PM
Do your Fenders have Skirts? Frederick L. Simson Jokes, Stories & Tall Tales 24 11-11-2008 08:51 PM
