Trailer Tires?? - Fiberglass RV
Old 09-26-2016, 01:25 PM   #1
flyby's Avatar
Trailer: Bigfoot 25
Trailer Tires??
I have a 1998 Casita Spirit Deluxe 17Ft on which I recently had the axle lifted and replaced the 14 in tires with 15 in. I bought (2) 15 inch tires and had them put on the trailer, completely forgetting about the spare. The tires that were recommended and put on were Carlisle Sport Track ST205175D15 rated at 1,820 libs.
When I went to buy the 3rd tire for the spare..I was told that these tires are not appropriate for my trailer. My trailer dry weight is 2,480lbs, with axle rated at 3,500lbs
Now I am still getting conflicting info..that I need E rated not D rated//radials and not Bias. Please help! What tires should I be using or what tires do you use or recommend?
I have no idea and know nothing about tires..I only know I want safe reliable tires that are appropriate for my Casita.
flyby is offline   Reply With Quote
Old 09-26-2016, 01:36 PM   #2
The tire rating of 1820 pounds is for each tire. 1820 X 2=3640. Your new tires are very adequate for your trailer.
Old 09-26-2016, 01:47 PM   #3
flyby's Avatar
Trailer: Bigfoot 25
Radials or bias?
Jack
Thank you..that was a very prompt reply! Now my question is radial or bias..these are bias tires. I (from what I've been reading about tires) think that radial's would be better suited for the type of travel we do. I am in the position to have the tires taken back by the dealer who put them on a replace with radials...would this be a good idea?
Old 09-26-2016, 02:07 PM   #4
Bias ply tires have stronger sidewalls which can be helpful in reducing sway. Radial tires wear longer but cost more. Most trailer owners do not wear tires out. They usually replace them because of age concerns. They at both serviceable for your application. If you would have peace of mind by changing over to radials and the price is reasonable, go for it.
Old 09-26-2016, 03:08 PM   #5
Trailer: 1980 Dolphin 14 ft
Just try to stick to "ST" or Special Trailer service tires, to reduce the amount of side-sway and hopping the trailer will do on uneven pavement. I put regular automobile tires on my Dolphin for awhile, and the first job when we stopped each time was to put the hangers back up in the closet.
When you retire, everyday becomes Saturday!
Owen & Rosemary
Formerly - 14'Dolphin, Looking for another!
Owen Lindsay is offline   Reply With Quote
Old 09-26-2016, 04:36 PM   #6
Originally Posted by Owen Lindsay View Post
Just try to stick to "ST" or Special Trailer service tires, to reduce the amount of side-sway and hopping the trailer will do on uneven pavement..
ST's come in both bias and radials.
Personally have used both and prefer radials.
Old 09-28-2016, 06:40 AM   #7
Some prefer bias tires because they have had better luck with them and longer life after having tread seperation with radials.
Trailer tires seem to be the luck of the draw and some choose LT (light truck) tires.
I error on the side of caution and replace tires and wheels every three years selling the old ones on craig's while they still look good
Joe
tires
P185-80 tires OR ST185-80 Tires ericmarlo Towing, Hitching, Axles and Running Gear 28 09-01-2023 12:35 PM
13" Tires or/vs 15" Tires? Tony Rubi Problem Solving | Owners Helping Owners 9 10-31-2013 10:35 PM
Trailer tires or car tires? serious sam Problem Solving | Owners Helping Owners 4 05-15-2011 10:13 PM
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 11:33 PM
