Trailer tongue storage box. - Page 2 - Fiberglass RV
Old 05-25-2011, 08:57 AM   #15
Trailer: 2005 13 ft Scamp
tongue box
Here is mine with 2 group 27 batteries and a small propane tank- purchased at Tractor Supply- $99
Wow, I like the looks of that box (with the two batteries and propane tank), but, don't batteries get hot? Should they be contained so tightly with the propane tank? Marg
Marg is offline   Reply With Quote
Old 05-25-2011, 09:17 AM   #16
melissab's Avatar
Trailer: 2012 Scamp 13 DLX
How did you secure the box to your frame?
Melissa in Florida
2016 Honda Odyssey
melissab is offline   Reply With Quote
Old 05-25-2011, 09:25 AM   #17
cpaharley2008's Avatar
The batteries do not get any hotter than they would in a battery box sitting on your tongue.
I installed 6 vents along side,back and bottom so it is cooler than sitting in the conventional battery box. No heat issues.
The box is attached with a "U" bolt which runs on each side of the frame up into the box and bolted. I installed a thin piece of plywood to give the bolt some area to "bite" other than the plastic box bottom. I think they were 4" bolts because the frame is 3"
tongue storage cpaharley2008 Modifications, Alterations and Updates 2 03-23-2011 07:02 PM
Black or White Tongue Box? Lisa H. Care and Feeding of Molded Fiberglass Trailers 19 06-01-2009 10:34 AM
Adding a tongue box Roy in TO Modifications, Alterations and Updates 6 06-03-2008 08:31 AM
Who's built a storage box on the tongue?? Vic&Kathy Modifications, Alterations and Updates 18 03-30-2007 07:26 PM
Tongue Box Barbara Gardin Care and Feeding of Molded Fiberglass Trailers 1 07-03-2006 08:03 PM
