trailer too tall to get in garage - Page 2 - Fiberglass RV
Old 08-27-2013, 11:28 AM   #21
Ian G.'s Avatar
Originally Posted by mkrueger View Post
Ian, how tall is your garage door opening and do you have any vents on the top of your boler? The biggest problem for me are the vents, although those wheels look like they might be small enough to work for me and might be worth looking into. As it stands right now, I've got the brake drums 3 inches from the ground and one of the top vents scrapes the top of my 7 foot garage door opening by just a hair. I have no room to play with for sure.
My garage door is just shy of 7' and I have a 14"x14" roof vent on top that is about 2" (maybe more) above the roof line. I need to install the 8" rims backwards on the hubs for them to clear the brake drums but this works fine and I have several inches of clearance to the door.
This shows the Boler outside my garage with the 8" wheels installed
Old 08-27-2013, 12:24 PM   #22
Trailer: Helite
Can U roll it in on the hubs?
Art VanDelay is offline   Reply With Quote
Old 08-27-2013, 12:32 PM   #23
Ian G.'s Avatar
I would never roll a trailer directly on the hub, it would be too easy to damage the hub face where the wheels mounts which would cause runout on the mounted wheel. also if the axle has a negative or "up angle" trailing arm configuration like most Bolers and Scamps the hub would not even contact the ground.
Old 08-29-2013, 11:46 AM   #24
Trailer: Fiber Stream
Maryland
Ok. Here's a long shot but. . Can you compress the springs using a chain or leaf spring compressor. This might give u just what you need to get under the door header.
JD1994 is offline   Reply With Quote
Old 08-29-2013, 12:23 PM   #25
That may work for some trailers, but typically Scamps don't have leaf springs. They ride on a torsion axle.
Old 08-29-2013, 12:32 PM   #26
Brian B-P's Avatar
The Scamp still has springs, even though they are not of the leaf type, or even steel - they're just rubber. I think it would be difficult to arrange a safe system to compress the springs significantly, which would mean pulling the suspension arms up toward the frame. I wouldn't try it.
This is just a "last inch" technique, since that's about all the travel available, but that's all that was being suggested.
Old 08-29-2013, 01:20 PM   #27
mkrueger's Avatar
Trailer: 13' Scamp
My bad, thanks for the correction. :-)
mkrueger is offline   Reply With Quote
Old 08-29-2013, 01:35 PM   #28
Ice-breaker's Avatar
Would seem to me that you could get a metalworking shop to cut out a pair of circular steel plates to the smallest possible diameter that would fit over your hubs. Have them also cut out the 4 or 5 holes matching the bolt pattern on your wheels and the center hub as well (if required). Then take an old bicycle tire and glue it over the edge of the steel plate as a driving surface, and who-la, you have a new set of wheels giving you maximum possible clearance. If that is not enough clearance, you would have to also remove your vents from on top of the trailer and set them up so that they can be readily removed and re-installed. If it still don't work, you are out of luck and will have to either increase your garage door size or park elsewhere.
Ice-breaker is offline   Reply With Quote
Old 09-03-2013, 05:24 PM   #29
mkrueger's Avatar
Trailer: 13' Scamp
Thanks for the suggestion Ian G! I went to our local Tractor and Supply store and purchased two 8" tires. Minus letting some air out of the tires it worked flawlessly! This is much safer than lowering the break drums on to car dollies for sure.
Old 09-03-2013, 05:39 PM   #30
Thomas G.'s Avatar
Be sure to put the larger tires back on before you hit the road.
Old 09-03-2013, 05:52 PM   #31
D Davis's Avatar
Trailer: Casita, previously u-haul ct13
Virginia
How hard would it be to replace the garage door header? rebox in after cutting about a foot higher. I would understand if you have an automatic door system, that maybe too expensive to replace...
D Davis is offline   Reply With Quote
MOVING a TOO-TALL cramper into the TOO-SHORT garage! HeathGal Problem Solving | Owners Helping Owners 5 10-19-2010 02:36 PM
dollies for getting your trailer into the garage Scott S. Modifications, Alterations and Updates 19 09-18-2010 08:01 PM
how to get a 7'6" trailer thru a 7' garage door bcomnes Problem Solving | Owners Helping Owners 24 08-09-2010 09:50 PM
How not to take a trailer out of a garage Thane Jokes, Stories & Tall Tales 11 04-17-2010 08:22 PM
FOUND- Need Trailer for Tall Guy in Calgary, AB Lisa Bronson Classified Archives 7 05-02-2009 01:05 PM
