Trailer wheel temperature - Page 2 - Fiberglass RV
Old 08-17-2015, 07:48 PM   #15
Trailer: 77 Scamp 13
Wheels are fairly simple mechanisms easily checked out for peace of mind and to avoid more costly repairs. If they check out as OK then check them by hand at the first rest area. Bingo you now know exactly what properly functioning tires on your trailer feel like in the ambient temps for your area.
My dad used to stop at the same gas stations just before we hit the highway to check the trailer and vehicle. I always figured it was just so us kids would hit the bathroom before the highway but no it was just a chance to make sure everything was as it should be after a bit of driving and before jumping on the highway.
Old 08-17-2015, 08:08 PM   #16
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Originally Posted by bullfrogeh View Post
The OP asked for a temp. I'd say - "If the standing 'outdoor' temp is plus 20 degrees C., then the tire and hub temps should be 20 degrees C." Anything otherwise, should be checked out, or rationalized. And, if it's anywhere near Zero Celsius - start shoveling the path to the barn.
Technically, the OP did ask what the normal temperature is. But does it matter if the normal temperature is 90 degrees, 110, or 120. The bottom line is that if you stop somewhere and haven't been applying the brakes excessively such as for a long downgrade, you should be able to grasp the hub and not burn your hand. In other words, if you can keep your bare hand on them, they are not too hot, regardless of the actual temperature.
parkliner
Wheel Bearing Temperature honda03842 Towing, Hitching, Axles and Running Gear 11 08-22-2012 10:52 PM
Cold Temperature Eggs Steve C Care and Feeding of Molded Fiberglass Trailers 11 11-01-2008 10:00 AM
High temperature silicone or caulking Paddy Morris Problem Solving | Owners Helping Owners 7 05-19-2006 09:13 AM
Tire Temperature - Infared Thermometers Legacy Posts Care and Feeding of Molded Fiberglass Trailers 7 06-21-2003 07:34 AM
Temperature (Rated G) Legacy Posts Jokes, Stories & Tall Tales 8 01-28-2003 03:45 PM
