Trailers that fit in garages - Fiberglass RV
Old 07-29-2015, 08:32 PM   #1
Hi folks,
I am renting a 2 car garage space which has a 16 x 8 overhead door. The rough opening for the door is about 7'-10" so I have 7'-8" max clear from slab to fully open door.
I am interested in finding (building if necessary) a trailer which can roll right inside. I have seen the schemes for achieving this. Fabric pop-ups, hard-sided pop-ups, Hi-Lo, switching the wheels to solid steel roller wheels, etc.
Some trailers are lower and have a pop-up center roof giving you a clerestory window all around, but in fabric.
I want all hard surfaces.
Thoughts?
Stevieboy
Stevieboy is online now   Reply With Quote
Old 07-29-2015, 08:45 PM   #2
If you're looking at used it can be toss up, truly
I own a 1988 Scamp Deluxe... No A/C. Originally, this trailer may have had enough clearance to run under an 8' garage door.
BUT, then I changed the axle and run 15" tires.
The important information I can give you is to MEASURE. Don't assume anything based on age or build type.
Best of luck
Old 07-29-2015, 10:40 PM   #3
IllAnnoy
Certainly any nominally stock Scamp13 will fit without A/C on the Roof. My 2004 with roof A/C fits comfortably through an ordinary "8 foot" door with a modicum of clearance to spare.
Newer Scamp13s (2007+) are a couple of inches taller and a DuoTherm A/C is a couple inches taller than my Coleman Mini-Mach.
Some clearance can be realized by simply using care and adjusting the tongue height up and down while entering the door. Most doors can gain full frame opening height with a simple prop to raise the door a little beyond the normal stopping point.
Reducing tire pressure can also reduce overall height of the trailer an inch or two without going all the way flat.
The Scamp 13 was originally designed to fit into a 7 Ft door opening, but gradual changes have increased the height to some degree.
Old 07-30-2015, 06:09 AM   #4
Tom Trostel's Avatar
Trailer: 1980 Bigfoot 17 ft
Anyone know how tall an Amerigo is? They always look very low to me. I bet they would clear an eight foot door.
Fiberglass RV - MRClaus's Album: Merrygo - Picture
Old 07-30-2015, 06:26 AM   #5
And there is always the opposite option of Donna's larger wheels, smaller "Parking" wheels. In the case of 4 on 4 bolt pattern wheels, they are available as small as 8", lowering a trailer up to 4" from the stock 13" wheel height, and a few roll in on bare rims.
Old 07-30-2015, 06:43 AM   #6
MRClaus's Avatar
Name: Rich & Linda
Trailer: Amerigo
Indiana
Thumbs up take off tires and rims
Hi Tom
Amerigo are low but it will fit my my garage but some of them aare taller.
you can take off the wheels and use a dollies to move in in too !
MRClaus is offline   Reply With Quote
Old 07-30-2015, 07:20 AM   #7
Stevie...I personally would not own a "pop-up", the all-tent-style trailer. Also, the "HILO" company is out of business and I would stay away from them. Some other campers that come to mind that you dont have to deflate the tires, etc. on are the Trailmanor and the Aliner campers. Not only will they fit in your garage, but would be easier to pull (less drag). The only problem? They're not "fiberglass". <_<
TrailManor Website | The Smarter Way To RV
Campers - Aliner
[QUOTE=Stevieboy;538398]Hi folks,
Old 07-30-2015, 07:29 AM   #8
Civilguy's Avatar
Puget Sound, WA
Originally Posted by Stevieboy View Post
I have 7'-8" max clear from slab to fully open door. <> I want all hard surfaces.
I garage a teardrop, but that might not be what you want.
Lil Snoozy notes 7'7". They place the AC on the back wall and keep the roofline clean. As Donna says, you really need to measure to validate. I have heard they are good about modifications; maybe the axle could be set up a bit differently to increase clearance.
Also try looking at Hunter Compact and Compact Jr. They have a small pop-top on the roof, so minimal "fabric"; I once had a '64 VW camper with that arrangement and found it acceptable. Someone noted their Hunter's dimensions here when they listed one for sale years ago:
1974 13' Hunter Compact II fiberglass, restored
Perhaps an old Boler.
Total height of Boler trailer?
If the driveway is sloped, that might be another factor to consider as it might reduce the effective clearance.
Ready to build your own? Try TNTTT.com
- "Wag more, bark less." -
Old 07-30-2015, 08:30 AM   #9
How big a trailer are you looking for? Any number of 13'ers are potential candidates, but larger trailers are hit and miss.
Among new trailers, Scamp and Casita 13' and 16' models and L'il Snoozy will possibly fit, based on current specs. Know that Scamp puts factory AC on the roof, which is a no-go, but Casita and L'il Snoozy use through-the-shell window AC installations.
With used trailers, especially older ones, it's even harder- original specs are hard to find, and mods can affect the height. The only way to be sure is to measure, as Donna said. I'm thinking most of the 13-16'ers would at least be candidates worth checking. Old torsion axles can settle a few inches, so be careful. If you buy one and then replace a worn-out axle, you may experience a growth spurt.
Since you mentioned building your own trailer, have you looked into the Happier Camper HC1? It's a 7' 4" 13'er with a rear cargo hatch and a flexible, modular interior. Not cheap, and it's a brand-new company with the attendant risks, but thought I'd mention it.
Consider yourself blessed to have an 8' garage. Lots of folks are stuck with the more common 7' doors and have far fewer choices.
Old 07-30-2015, 08:42 AM   #10
Monte W's Avatar
Trailer: Perris Pacer
Hi Steve, I owe a Perris Pacer and it fits in the garage! Also, if you have a air compressor, you can alway deflate the tires a little to make it work. A pain I know but....... Hope this helps!!
All the best, Monte
Monte W is offline   Reply With Quote
Old 07-30-2015, 09:28 AM   #11
Being somewhat sarcastic, but from observations, building ones own trailer reminds me of three street signs:
"Slow - Bumps Ahead", "Rough Road Ahead" and, halfway down that block "Dead End"
Try something that is already rolling down the road before you try to invent/reinvent the wheel.
Old 07-30-2015, 09:37 AM   #12
Trailer: Escape and Boler
My 13 Boler (1973) went into my normal 8' (nominal) garage.
MEASURE is the important matter - already advised to you
and if only an inch or so - let air out of tire and have an 'air tank'
(cheap) which you can fill at local friend or garage.
Lindenguy is offline   Reply With Quote
Old 07-30-2015, 10:57 AM   #13
The Minimalist's Avatar
Louisiana
I'm with Bob. Easier to build a garage or carport to fit what you have, or get a cover.
Clif
Old 07-30-2015, 12:02 PM   #14
IllAnnoy
8" wheels are commonly available for 5 on 4.5 bolt pattern as well.
Propane Heater Retro-fit - Scamp lenny247 Modifications, Alterations and Updates 15 12-12-2015 03:49 PM
Question: Do tall people fit in these trailers? Ev Jones General Chat 20 12-11-2006 08:02 PM
Do eggs fit in your garage? Clint Problem Solving | Owners Helping Owners 11 07-23-2006 01:19 AM
Need to Fit Garage Height Legacy Posts Problem Solving | Owners Helping Owners 9 08-21-2003 02:26 PM
How many people fit? Legacy Posts Problem Solving | Owners Helping Owners 10 01-31-2003 08:30 PM
