Trillium 1300 1975 window - Fiberglass RV
Old 06-19-2016, 06:26 PM   #1
Hi all problem with a few windows. One I noticed the bottom of three on side of trailer appears to have broken inside. One above sink will not open anymore. I'm looking for some remedies on these problems. The side window appears to have a metal break. What tools are needed to perform and what supplies to fix the windows
Thanks for the help
Tony from Ontario,Canada
agreco is offline   Reply With Quote
Old 06-22-2016, 02:40 AM   #2
David Tilston's Avatar
The construction of the windows is fairly simple. The gear box sometimes needs to be replaced, or the connecting bars. Pictures would help.
Old 06-22-2016, 05:08 AM   #3
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Yep, they definitely can be rebuilt. You might likely be better off to pull the window first. Most of the components, like the crank gear box, and the cast arms that connect each window to to the aluminum bars are all available for purchase new. So too are the rubber components.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-24-2016, 07:19 PM   #4
Hi guys the trailer is out of town but I can take a pic of it when I am there next weekend. I am in Ontario Canada. Do you know any dealers that would sell me the materials?
Old 06-24-2016, 07:20 PM   #5
Do The windows come out from the inside or the outside? What tools are needed in materials to take out and put back in?
Old 06-25-2016, 05:20 PM   #6
There are several theads on this subject:
My first Trillium window thread.
There are black plastic screw covers on the outside of the windows. It takes a gentle hand to remove them without breaking them. Then undo all the screws. Pull the window out from the bottom. It kinda hooks around the top side.
Old 06-26-2016, 11:57 AM   #7
Trailer: Trillium 14"
Replacing wooden frame for windows
Hi all.
I hope somebody in the group can help me with this question:
All wooden frames in has to be replaced. Do the new frames need to be glued on? Is it enough to let the screwes hold the frames?
Thank you.
danishtrillium is offline   Reply With Quote
Old 06-26-2016, 11:58 AM   #8
[QUOTE=danishtrillium;595064]Hi all.
All wooden frames has to be replaced. Do the new frames need to be glued on? Is it enough to let the screwes hold the frames?
Thank you
Old 06-26-2016, 03:41 PM   #9
Ed Harris's Avatar
[QUOTE=danishtrillium;595065]
Originally Posted by danishtrillium View Post
Hi all.
Thank you
I have done 2 trailers so far and just let the screws hold the plywood together.
You need to clamp through the open windows or do something to help position them for screwing to the window frames but once they sandwich the fiberglass they are in there pretty solid.
I did use spray adhesive then to reattach the elephant skin to the plywood on the inside as there is not much else for it to hold to.
Old 06-26-2016, 06:00 PM   #10
Hi Ed!
Thank you for your reply! Your tips are very helpful!
Would you recommend putting the butyl tape directly onto the Fiberglas or onto the aluminum windows?
Thanks in advance!
Kim
Old 06-26-2016, 09:44 PM   #11
Carl V's Avatar
Trailer: 1981 Trillium 5500
Quebec
Same here.
And butyl tape goes 1st on the window frame, not the trailer.
Kim, you may want to look at my thread, I've done all the windows on it and took a lot of pictures.
Working on a Trillium 5500
Old 06-26-2016, 10:34 PM   #12
Hi Ed.
Thanks so much for sharing your pictures.
Old 06-27-2016, 04:38 AM   #13
Ed Harris's Avatar
Pics are not mine.
I put the butyl on the window frame though too.
The holes for the windows in the fiberglass shell will not be perfect and the tape needs to seal the entire window perimeter so the only way to make sure that this is what happens is to tape the windows and then let them seal the hole.
Have fun,it is worth the effort!
trillium
Wanted: WANTED - Trillium 1300 - Shelves, door window, kitchen window and frame David Tilston Parts: Buy | Sell | Trade 6 10-20-2012 09:13 PM
1975 Trillium 1300? Val L Care and Feeding of Molded Fiberglass Trailers 9 05-01-2009 09:38 PM
SOLD-1975 Trillium 1300 For Sale Dave Baston Classified Archives 3 11-12-2007 05:22 AM
SOLD: 1975 Trillium 1300 (13') Dave Van Vugt Classified Archives 3 08-23-2007 08:29 AM
Plumbing Problem in 1975 Trillium 1300 John L. Problem Solving | Owners Helping Owners 7 09-25-2006 08:43 AM
