Trillium 1300 dinette leaf storage - Fiberglass RV
Old 06-06-2014, 09:42 PM   #1
I followed all of the instructions for turning the bed into table and all but don't see in the instructions where to store the leaf when not in use.
JBjunior is offline   Reply With Quote
Old 06-07-2014, 06:31 AM   #2
Noreen Bradshaw's Avatar
What leaf? My 1300 had a one piece table top. It was lowered to make the bed. Nothing left over.
Noreen Bradshaw is offline   Reply With Quote
Old 06-07-2014, 07:03 AM   #3
David B.'s Avatar
Our 13' Scamp Deluxe had a small table that needed a leaf to make a large bed, and it was a hassle to set-up/tear-down and store. I changed the table out to a hinged two piece top so we could still use the very handy small table, or an enlarged version when needed, without having to stow away the extra leaf every time. This modification really made it easy to make the transformation from table to bed (along with just using a double sleeping bag that stowed easily).
Happy Camping
Dave & Paula
Old 06-07-2014, 07:35 AM   #4
It has a leaf that inserts in the middle for transfer from short table to long table and to the bed. It has a place and is easy to use, I just can't remember where it attached to from when I started.
Old 06-07-2014, 07:54 AM   #5
Trailer: 1976 Trillium 1300
That must be an owner mod because as Noreen states the 1300 have a one piece table I believe.
kootenaigirl is offline   Reply With Quote
Old 06-07-2014, 08:32 AM   #6
Roy in TO's Avatar
Storing the leaf in the closet makes sense to me.
Old 06-07-2014, 09:06 AM   #7
How about a picture?
Old 06-07-2014, 10:00 AM   #8
Name: Dennis & Linda
Trailer: Leocraft 17ft fiberglass rv by Monarch Industries
Leaf Table Storage
Hi folks! Our 1975 1300 came with a full table from the factory. Later Trillium came out with the leaf table so we drove to the factory and had them exchange our full for the leaf. We watched the installation while we waited. 'Tom' installed the leaf against the back wall of the closet. He cut out a piece of the insulation at the top where the leaf touched the wall and glued a small square piece of wood to the outer glass wall. He then screwed on to the wood a bolt lock that held the leaf in place . Worked like a charm. But I believe I moved it to the right side of the closet later as we found it easier to access.
Dennis Schultz is offline   Reply With Quote
Old 06-08-2014, 07:29 PM   #9
David Tilston's Avatar
The leaf table was an option, more frequently selected on the 4500, (part of the Deluxe package) but available on the 1300. I like the table without the leaf. It is like a bar table then.
If your trailer came with the leaf table, Trillium should have already installed a block of wood, under the ensolite, on the back wall of the closet, that has a sliding bolt type of gate latch. Also another block is installed on the bottom of the closet. This is about an inch, maybe an inch and a half from the back wall of the closet. The side of the leaf is inserted in the groove made by the bottom block. The bolt is slid up to insert the top of the leaf. Then, the bolt is allowed to fall, holding the leaf in place. The top of the table, that is visible when the leaf is in use, should be facing the back wall of the closet, because the sliding bolt beats up the leaf while in transit.
Old 06-08-2014, 08:10 PM   #10
The problem with the leaf being stored in the closet which I have on mine is that you have to move everything out of the closet to get it in or out. I just slide it under the table on end and it is much easier to set up and it is never in the way
Mikmay is offline   Reply With Quote
Old 06-14-2014, 03:54 AM   #11
Thanks for all of the replies. I can get a picture some other time, currently in a cross Canada to Alaska trip, should be done soon.
trillium
CANADA - 1980 - Trillium 1300 - Factory Front Dinette - $3500 David Tilston Referrals: Molded Fiberglass Trailers 2 09-15-2012 03:55 PM
Wanted: Above Dinette Storage Shelf with light for Trillium 1300 Rodre Classified Archives 2 04-15-2011 10:25 AM
Storage, Storage, and Storage Legacy Posts Problem Solving | Owners Helping Owners 18 11-20-2002 10:43 AM
Storage, Storage, and Storage Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
