Trillium 1300 Frame Question - Page 2 - Fiberglass RV
Old 11-06-2012, 07:55 PM   #15
Trailer: 2008 17 ft Casita Spirit Deluxe/'78 Trillium 1300
Arkansas
Thank you!
Spanke, I am green with envy. It's almost a shame to cover up that beautiful frame with the body.
Carol, I KNEW it was easy to post pics. I think my frustrations with the trailer are addling my brain.
And David, WOW! You're more thorough than my doctor! Thank you so much for the diagnosis. I think you've given me a little hope because I'm now excited to get out there and get busy again (as opposed to hiding under the covers). As for the floor, since it felt so firm, I was just going to leave it, but now I think I'll have to pull up the linoleum and carpeting to check for rot. There is no flooring in the dinette storage areas or the furnace area, and under the replacement fridge there's a thin, dry, original floor area topped with a piece of plywood screwed down over it for some reason. I'll start a new thread on the floor if I can't identify any issues I find.
Thanks again for all of your help!!
Ruth
Ruth C. is offline   Reply With Quote
Old 11-07-2012, 11:28 AM   #16
David Tilston's Avatar
Ruth,
Attached are two pictures from the bottom of one of my 1300 trailers. You can see the two cross members near the front, but nothing till just before the axle. you can also see the extra metal plates that were welded in to reinforce the frame. Kinda looks like they went overboard. Those plates are almost 3 feet long on the sides.
If your wood beams are a fix for rotten plywood in your floor, It seems like a good fix. They probably don't add more then 50lb. If your floor is rotten, which is unlikely, it would be quite a job to replace.
Old 03-14-2013, 04:28 PM   #17
Trailer: 1980Trillium 1300
Frame of 1300 Trillium-1980
Here is my frame:
Old 03-14-2013, 06:38 PM   #18
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Whatcha got goin' on there, Randy? Total frame-off restoration? If so, you might think about starting a whole new thread on the subject.
We love to follow individual projects like that!
Francesca
Old 03-14-2013, 06:47 PM   #19
Francesca
...Hi, there. I am a...brand new member, just ....yesterday but I might have...hundreds of pictures about...DIY for your trailer, actually...my trailer. I am just 5feet 2, weight 130lbs but believe me or not, ALL I DO BY MYSELF, including...pulling the whole frame off the...shell, of course with....tricks. Please welcome to...ME, brand new member. Some.... of my tricks....might help...someone. Cheer!...
Old 03-14-2013, 06:53 PM   #20
Mother lode!
Pleasepleaseplease do post a from-the-beginning type thread..."before and after" pics mandatory!
Here's a link to the right part of the site to start such a thread in: Modifications, alterations, and updates.
We'll be watching for it...
Francesca
P.S.
By the way:
Welcome to the site!
Old 03-15-2013, 06:27 PM   #21
Mother lode!
Francesca
P.S.
By the way:
...Thankyou for your encouragement. I will keep tag of all steps, photos,...from beginning to the end(must be a lot, though). Right now, I am just in state of beginning of restoration/modification. When I bought the Trillium, it only had 117vac circuitry, one small fridge, a little propane oven. Inside @ front driverside corner, fiberglass shell had cracks and no water tank what-soever.. Here is my plan: 1/ Check, reinforce frame, pain it... 2/ Run a combination of electrical system, including 117VAC, 12VDC from battery charger/booster and an independant 12VDC from battery. That includes adding reading light for each bed(3 beds), extra 12VDC power supplies, control panel with breaker, switches, lights as indicators, fan for roof vent, backup alarm when in reverse and back up flood light @ rear bumper for night time in...the bush. Also add air condition(heater I preffer portable)...3/ Doing body work of shell, re-polish all alum windows and re-seal them and finally...paint the whole shell in a rent shop. When it gets home, adding stripes, letters or might be some weird pictures with air-brush( I wish I got the time). Also add water tank with 50liter capacity. The old floor was carpet, I will replace it with plastic laminate/water resistant one. Not mention about redo the bunk bed with aluminum frames, pull out mini talbe with cup holders...also relocate spare tire with bike rack at rear...Bottom line, I love to work for...me, some kind of hobby. I might show you the utility trailer I made from several years ago with....Honda civic rims and tires. Cheer.
trillium
How to beef up Trillium 1300 frame? H. Fred Fuller Problem Solving | Owners Helping Owners 7 03-17-2013 12:06 PM
Wanted: WANTED - Trillium 1300 - Shelves, door window, kitchen window and frame David Tilston Parts: Buy | Sell | Trade 6 10-20-2012 09:13 PM
How do I remove the body from the frame? 1971 Trillium 1300 coalminecanary Modifications, Alterations and Updates 26 06-11-2012 09:41 AM
trillium 1300 frame crack recall info colinn Problem Solving | Owners Helping Owners 8 10-18-2008 02:36 PM
Trillium 1300 Frame Bargain TomA Classified Archives 0 06-10-2008 05:03 PM
