Trillium 1300 Furnace - Fiberglass RV
Old 01-09-2010, 02:48 PM   #1
Trailer: 1975 Trillium 13 ft
Does anyone have suggestions or experience with adding a furnace to this trailer. Seems the common furnace in these small trailers is the Suburban NT-16SE, but the length (21") exceeds the area below the sink by nearly 3 inches. Could the furnace be located in the bench, discharging under the table? Looking for suggestions before I purchase the furnace.
Shaun D is offline   Reply With Quote
Old 01-09-2010, 05:11 PM   #2
Hi there Shaun:
I used to have a 73 Trillium 13', and it had the furnace installed below the closet door.
I am not sure if it was built that way, but it worked fine, and I never noticed much heat at the bottom of the closet, inside, as you could pull the bottom piece of wood,
(base of the inside of the closet) right out to access the furnace, and the wood bottom had a silver heat shield of some sort, on the furnace side?
Not sure if your closet door goes right near the floor or not?
Good luck with it, Jake.
Jake is offline   Reply With Quote
Old 01-10-2010, 08:34 AM   #3
Daniel V.'s Avatar
Trailer: -
I think some of the new Trilliums have it in the bench. If you're considering under the closet, exhaust fumes might be a problem if you like to hang out on that side, i.e. picnic table, under the awning or inside an add-a-room.
Daniel V. is offline   Reply With Quote
Old 01-10-2010, 09:43 AM   #4
Ed Harris's Avatar
My 1300 had the furnace under the sink and it was flush.
On the 4500 it was under the closet.
Remember anywhere you locate the furnace will need a hole outside for the exhaust.
Ed Harris is online now   Reply With Quote
Old 10-06-2010, 04:19 PM   #5
Trailer: 1976 Trillium 13 ft
Installing a New Furnace
I have a 1976 Trillium 1300 I just purchased that does not have a furnace . To avoid cutting out the fiberglass under the sink , it appears the Atwood 7900 Everest series is the best . If you look at the shape of the rear , it is tapered to match the contour of the trailer . I will also need a converter to supply the furnace .
The Elixir 25 amp converter and the furnace are both on Ebay right now . The RV Pirates in Canada make the costs too high to obtain one here .
I have a comment about using the Mr.Heater or little Buddy propane heaters without air exchange . Are you not worried about the Carbon Monoxide produced ?
I plan on using my Trillium during the winter . Any comments or suggestions ?
Thnx , S.Ryan
Stephan G Ryan is offline   Reply With Quote
Old 03-08-2015, 02:56 PM   #6
Trailer: In the market
Manitoba
How much noise does the heater for the 1300 make while running. I am considering putting a heated floor in, anyone else tried that?
Dustmote is offline   Reply With Quote
Old 03-16-2015, 09:22 AM   #7
David Tilston's Avatar
Susan, This is a very old thread. The furnace that the 1300's were built with are called gravity furnaces, because they depend on convection to move air. There is no fan, they consume no electricity. They make very little noise. A faint hissing.
Old 03-16-2015, 09:55 AM   #8
Manitoba
Thank you. New to this site.
Old 03-16-2015, 10:21 AM   #9
Welcome Susan. I am partial to Trilliums. I own six of them.
A heated floor is an interesting idea. Do you plan to heat with a boiler, or electric?
Old 03-28-2015, 07:01 PM   #10
Trailer: 1972 Trillium
I have a 73...........
I have never seen another Trillium and assumed them to be out of production. I too wanted to use mine in the winter...(I'm a Minnesota boy)... so, being I live about an hour from the Scamp factory, I pulled her up there and had them install a furnace. I wasn't happy with the location they chose, but they said it was the only place it would fit. I had already pulled out a non-working frig and stove top so they put it there. It was too long to fit right, but they got it in there anyway. It works! I also insulated the trailer with 1 inch blue foam. Glued it all up. (major pain) Then covered it with the fabric they use in the Scamps......(also a pain) The wife and I took it out in about 10 degree F weather and the furnace cycled about 4 times an hour if there was any wind. We did spend one night at about 30 F with no wind and it cycled once an hour. We hung reflectix over the windows to save heat and give some privacy. Used reflectix under the beds. To do it over again I would have someone shoot it with urethane foam and seal it up real good.
AJnK is offline   Reply With Quote
Old 08-22-2019, 08:26 PM   #11
We turned on our heater for the first time, we’ve owned the trailer for a month now, we put it on 1, the lowest setting, it warmed up the trailer quite well but noticed the closet bottom door and fibreglass getting very warm. It also got very warm in the trailer after an hr so we turned it off. It shouldn’t be that warm after an hr should it? We should be able to run it during the night without getting too hot at low, do you think something is wrong with it?
Penelopeblue4500 is offline   Reply With Quote
furnace, trillium
Trillium 1300 furnace removal... David Swinnard Problem Solving | Owners Helping Owners 7 11-28-2015 12:37 PM
OH | 1981 Trillium 1300 Trade for a Trillium 4500 Gene Griffin Classified Archives 13 03-06-2011 08:27 AM
Wanted - Furnace for 1974 Trillium 1300 Tracy S. Classified Archives 1 10-08-2010 11:48 PM
73 TRILLIUM 1300 Joseph Olajos Classified Archives 0 01-25-2009 11:47 AM
