trillium 1300 upper cabinet flaw fix? - Fiberglass RV
Old 03-20-2016, 01:56 PM   #1
I have just purchased a new to me '73 trillium in great shape, as I am cleaning it up, I think I found a flaw in the upper cabinet original fibreglass work that pushes the T molding down.
Here is a pic...
Because fibre glass does not bend the only solution I can think of is to use a cut-off wheel to remove and "re-mold" it.....
Any one have experience with this?
Thanks!
t096772 is offline   Reply With Quote
Old 03-20-2016, 02:01 PM   #2
heres the pic:
Old 03-20-2016, 02:56 PM   #3
Trailer: Trillium Outback 2004
Roof sagging Steve?
BarbinBC is offline   Reply With Quote
Old 03-20-2016, 07:53 PM   #4
No the roof looks good, the cabinet is not attached to the roof in the upper front section where you can see that the edge is not formed straight. It creates an open seam too wide for the Tmolding to cover it
Old 03-21-2016, 11:09 AM   #5
Steve..
Mine is a '75 Trillium and it looks the same as your pics BUT mine has a nice white edge moulding that, I would put money on, is original.. You can get the same moulding at most hardware stores as it is used for edging on thin plywood and aborite where there is a transition between materials..
You will need enough for all 3 edges and then put the side ones on first and cover the exposed ends with the third or "front" piece.. It will look like new ;-)
Chris from Comox..
Chris from Comox is offline   Reply With Quote
Old 03-21-2016, 12:04 PM   #6
This is on the kitchen cabinet?
I would have to unglue the ensolite to get to the side edges and the front edge is not straight so I don't think the trim would go on without cutting it .
It really looks like the fg was not laid down flat when the cabinet was made
trillium
Trillium 4500 Plywood Upper Cabinet Repair David Tilston Care and Feeding of Molded Fiberglass Trailers 8 11-12-2011 09:29 AM
Scamp design flaw, floor rot? Ken C General Chat 8 07-16-2008 05:42 AM
Need Upper and Lower Cabinet Advice Bailey Modifications, Alterations and Updates 3 04-09-2007 10:58 PM
Holding Open (UP) Upper Cabinet door Legacy Posts Problem Solving | Owners Helping Owners 15 05-18-2003 07:48 PM
