Trillium 5500 - Fiberglass RV
Old 09-29-2013, 12:51 PM   #1
Trailer: Trillium 5500 1981
Smile Trillium 5500
Hi there, we own a Trillium 5500 and recently had the belly band replaced which caused a bit of damage to the paint. Could someone advise what paint we should use to touch it up. It is a cream one.
thanks for any suggestions/'help
Dorothy and Ann
dorothyb is offline   Reply With Quote
Old 09-29-2013, 12:53 PM   #2
Dorothy and Ann
Are you sure it's paint and not the original gelcoat? The solution may be the same or may be not... depending on your answer.
Old 09-29-2013, 12:59 PM   #3
Smile Trillium 5500
thanks for replying Donna, we believe it is the original gelcoat, not absolutely certain, but that is what we think. Thanks for any help.
Dorothy and Ann
Old 09-29-2013, 01:05 PM   #4
Ice-breaker's Avatar
Any pictures you may have that show the extent of the problem may help in finding a solution.
Ice-breaker is offline   Reply With Quote
Old 09-29-2013, 01:06 PM   #5
Dorothy and Ann, I can offer you this post. It's for a 1978 4500 Trillium... but they said it's Ivory. Wonder if that's the same as yours? And, it's a paint match to the gelcoat.
Exterior paint match for 1978 Trillium
On Edit: I found another one: Trillium Jubilee Paint Match
Hope this helps!
Old 09-29-2013, 02:01 PM   #6
Hello Anne where in Ontario are you located . I'm in amherstburg I have a spray can I purchased from Canada salvage in Windsor it is a perfect match . The can make is VHt rapid dry enamel the color is rd-428 gloss almond it is the closest color I've ever found Spray it on your seam and coat it with zep will come out perfect pm me if you need more info
Mikmay is offline   Reply With Quote
Old 09-30-2013, 11:43 AM   #7
Smile Trillium 5500
hi there, we are in Toronto, any idea where we can get this here? Thanks for the info, we realise it probably will not be exact but close is good!
Old 09-30-2013, 11:55 AM   #8
Smile Trillium 5500
thanks guys for all the responses, I have a number of leads now to follow up. I am sure something will pan out.
Dorothy and Ann
trillium
1976 13' Trillium and 1980 Trillium 5500 18' Jenn Classified Archives 10 05-19-2010 02:36 PM
trillium 5500 Janice M Care and Feeding of Molded Fiberglass Trailers 10 02-07-2008 06:43 PM
Trillium 5500 Al Stansell General Chat 25 06-28-2007 08:04 PM
Trillium 5500 Chester Taje General Chat 14 02-27-2007 07:20 PM
TRILLIUM 5500 Classified Archives 0 01-01-1970 12:00 AM
