Trillium Belly band - Fiberglass RV
Old 08-20-2012, 10:20 AM   #1
Barrett family's Avatar
Trailer: Trillium 5500
Quebec
Trillium Belly band
Hi all
Spent all morning scrubbing the trill. The belly band had layer over layer of disgusting black and greening silicone. Removed it, now I find that the belly band was held on by the silicone on one side. Rivits are toast. So how do I get the rubber out and back in so I can re-Rivet it. Also what do I re seal the band with?
Curtis
Ps my marine hull cleaner made the trailer clean enough to eat off of.
Barrett family is offline   Reply With Quote
Old 08-20-2012, 10:43 AM   #2
Quebec
I want to fix this right but were goin camping Friday! Any solution ideas to get me through?
Old 08-20-2012, 10:47 AM   #3
je.bedard's Avatar
Trailer: Trillium 13 ft
The rubber insert is really easy to remove. You simply pull it out. When you want to put it back, you just squeeze it between your finger and insert it. I hope you can understand my French explanations loll
je.bedard is offline   Reply With Quote
Old 08-20-2012, 11:21 AM   #4
David Tilston's Avatar
In my OPINION, the belly band is the major design flaw of the trillium. It should be removed, then cut, or grind out the metal plates that hold it on. Then fibreglass, and bondo over it. Some then add a self adhesive belly band back on, but I prefer the look with no belly band.
Just search "belly band" and you will find several links on how to do this. I like this one:
http://www.fiberglassrv.com/forums/f...and-46424.html
Old 08-20-2012, 11:29 AM   #5
je.bedard's Avatar
That's what I've done. Simply removed it
Old 08-20-2012, 12:04 PM   #6
Quebec
I'm gonna follow suit. All the steel where the rivets are supposed to go is crumbling and bulging. But to get me through the weekend I've bought a tube of marine Goop, it's stuck on and hopefully I don't lose it in new York, new Hampshire or Vermont! Will caulk around the top just as a temporary measure.
Old 08-20-2012, 12:05 PM   #7
Quebec
Photos
Old 08-20-2012, 01:23 PM   #8
Attachment 50203
That looks great! Just out of curiosity, what year is your Trillium? The reason I ask is that you have a Bargman L400 door latch. Most Trillium 1300's have an L300. I have one of each. My 1977 has the L400 as well.
I am working on removing the belly band from my first 4500 now. I plan to remove it on all four of my Trilliums.
Old 08-20-2012, 01:40 PM   #9
Quebec
1980. I'm waxing right now with 3M marine restorer and wax. Coming along nicely. 4 trilliums! You should consider separating them while in storage or looking at spaying or neutering !
Old 08-20-2012, 01:45 PM   #10
je.bedard's Avatar
Haha you know a bit more about trillium than me.. Mine is a 1980 bought in 2007 for $1500. Really good condition.
Old 08-20-2012, 04:26 PM   #11
Roy in TO's Avatar
What was the hull cleaner?
Looking forward to before and after pics.
Hope you have a great trip.
Old 08-20-2012, 04:34 PM   #12
Quebec
Spray nine boat bottom cleaner
Old 08-20-2012, 04:35 PM   #13
Quebec
Finished product
Old 08-20-2012, 04:39 PM   #14
That is an awesome deal, (steal?). You even have the kitchen window. 1980 was near the end of the production.
Old 08-20-2012, 06:25 PM   #15
Trailer: 1978 Trillium 4500
Um... maybe a stupid question here: can you just climb on top of that roof and crawl around, scrubbing and spraying it? I mean, it'll hold your weight and everything? The roof doesn't give? Because, if you can just climb up there and work on the roof, I'll be doing that to my Trillium, too!
spotcatbug is offline   Reply With Quote
Old 08-20-2012, 06:38 PM   #16
Quebec
It held me, 200... 215 ish pounds. A sponge and a coors light no problem while scrubbing.
Old 08-20-2012, 08:42 PM   #17
Stay near the edge, it helps distribute the load
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 08-21-2012, 10:48 AM   #18
I use a 15 year old teen age daughter for anything that requires getting on the roof. Gotta love the family bonding time.
Old 08-21-2012, 10:50 AM   #19
je.bedard's Avatar
15yo... Its probably the last year she'll listen to what her dad ask her to do... Loll
trillium belly band Rarebird Problem Solving | Owners Helping Owners 31 04-24-2018 04:17 PM
Trillium Belly Band Randy Bishop Problem Solving | Owners Helping Owners 9 05-16-2013 05:00 PM
Trillium Belly Band freddie b Problem Solving | Owners Helping Owners 0 05-04-2010 07:01 PM
trillium belly band Barry Konkin Problem Solving | Owners Helping Owners 3 01-21-2009 05:13 PM
