Trillium door lock - Fiberglass RV
Old 07-16-2012, 03:07 PM   #1
Trailer: Trillium 1300
Trillium door lock
On the maiden trip with my 1975 Trillium, the door came open while driving. It was locked at the time and thank goodness, no damage. Anyone else experience the same problem ???? Other than replacing the door knob and lock, any ideas on fixing this ????
Shelley Brinacombe is offline   Reply With Quote
Old 07-16-2012, 03:31 PM   #2
US
If you do end up needing a new one, i think i saw them for sale at the trilliumrv parts page. Good luck.
Old 07-16-2012, 06:50 PM   #3
Alistair Camelford's Avatar
Trailer: Trillium 13 ft 1973
door lock
I replaced the original with a Trimark Lock . There is a thread on this. Cost about $175 with shipping and taxes to Canada...should be $30 or $40 less for the USA
It is a super tough piece of machinery!
Alistair and Inge in The Road Toad
Alistair Camelford is offline   Reply With Quote
Old 07-16-2012, 07:27 PM   #4
Same thing kept happening on my Boler. Door would be latched and locked. A half hour into the trip, I'd see it in the mirror, hanging open. Wound up using a bungee cord to run diagonally across the door from the upper hinge to the wheel-well to make sure the door couldn't open more than a half inch or so en route, until I could get home & fix it. In my case, it wasn't the latch, it was the striker that was worn out. Made up a new one by bending up an old house door striker and installing that right over the original.
Old 07-16-2012, 10:35 PM   #5
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Dave's right (as usual) most often an unwanted door opening can be traced to a bad (or mal-aligned) striker which the first place I'd look into and repair before I even considered a new/used/other lockset.
Old 07-17-2012, 05:36 PM   #6
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
Ditto on Dave's latch suggestion. I made a new strike for our '78 Trill and bolted it in place instead of rivets with a reinforced plate on the back side because the loosened rivets had worn the fiberglass so badly. I also took the lock apart and cleaned and lubed it. Big difference in the way it latches now. After more than 30 years mechanical devices sometimes need a little love and attention.
Reid Larsen is offline   Reply With Quote
Old 07-17-2012, 06:55 PM   #7
David Tilston's Avatar
Had this happen lots on the trip I just got back from. I lost the middle screw on the trailer side of the top hinge. The door sagged enough that the latch must have bounced out from behind the striker plate. My wife bungied the inside handle to the closet.
My door never has fit right. I will be pulling out all the windows and fittings to paint my trailer. I expect to put allot of work into making the door fit better.
Old 07-22-2012, 07:19 PM   #8
Name: Mike and Linda
Trailer: 1980 BIGFOOT 17'
These door issues remind me of an incident about a year ago whereby my wife, Linda, attempted to open the door on our '76 Trillium after a lengthy and albeit rough road trip only to have same fall completely off onto the ground at her feet!! After ensuring that she was OK, I must have laughed for an hour...spent the next 2 days of our holiday mixing epoxy and filling the cavity where the hinges screw to the shell. This repair seems to have held well, so far at least.
woodm is offline   Reply With Quote
trillium
Trillium 1300 door lock RKurelowech Problem Solving | Owners Helping Owners 2 09-17-2011 07:47 AM
Trillium door lock won't close itself Rick G Problem Solving | Owners Helping Owners 30 07-04-2011 09:10 PM
2004 Trillium Door Lock theresa p Problem Solving | Owners Helping Owners 13 11-29-2010 06:00 PM
1974 Trillium door lock Barry Konkin Problem Solving | Owners Helping Owners 13 06-03-2009 09:56 PM
Door Lock-Trillium 1974/1300 Mary Lynn K. Problem Solving | Owners Helping Owners 4 04-15-2009 08:18 AM
