Trillium door lock won't close itself - Fiberglass RV
Old 11-25-2010, 01:44 PM   #1
Rick G's Avatar
Trailer: former Boler, now 1980 Trillium 4500
Question Trillium door lock won't close itself
Hi all,
I am looking for information about my door lock and latch. It appears to be the original one in my 1980 Trillium 4500.
The problem I am having is that the door does not latch smoothly when closing. The door will close until it strikes the striker plate, then stop. This is because the latch seems to have a very strong spring on it, which prevents the striker from retreating when it hits the striker plate. Instead, I have to open the latch handle to get the striker to retreat, and then close it after the door is shut to get it to latch. So, it takes two hands to close the door, not a good thing.
The door closes fine and stays closed and locked as required. I just wish it would close more easily. In the pictures below, you can see significant wear on the striker and striker plate, which is to be expected after 30 years. However I donít know whether a simple adjustment of the plate would be possible or make any difference. I do see the two screws on the interior of the lock, but I have not yet explored whether I can remove that plate and service the parts. A job for the springtime.
On my previous Boler, the original door latch/lock was completely hooped when we bought it. I replaced it with a generic one from an RV store, which worked great. We could just let the door close gently and it would latch itself, much like a screen door on a house. I would like to get the same result on the new trailer. However, this door lock makes a huge hole in the door, so I can't easily replace it with a generic one.
I guess my real question is: what kind of door lock is it? Can I get repair or replacement parts, or replace the whole thing? Would a replacement be any better at gently closing by itself than this one? It does not seem to match the Bargman pictures I have seen.
If I canít find or fix anything, I am considering changing the striker plate to one of those house-screen-door types that has a spring loaded vertical bar. The bar is pushed aside as the door closes and then springs into position behind the striker to fasten it shut. However, I would prefer to have the current one work properly, if possible.
By the way, the trailer exterior looks much better than the picture. It is just frost on the trailer that makes it look bad.
Thanks,
Rick G
Rick G is offline   Reply With Quote
Old 11-25-2010, 03:09 PM   #2
Chris McVeigh's Avatar
Trailer: 1978 Trillium 4500
Nova Scotia
Holding the latch out while closing the door is how we have been closing our trailer door since new - always thought slamming it shut would be too hard on the unit. Maybe powdered graphite would make things slide easier.
The Bargman L400 lock on the old Trilliums is now out of production and is hard and kind of expensive to aquire these days. Bargman makes another squarer lock that would fit - that is what they are using on newly built Trilliums these days ( TrilliumRV , Outback, etc ). You could order one from them but again I don't think it would operate any differently.
Those 'elusive' Bargman 400 locks
Chris McVeigh is offline   Reply With Quote
Old 11-25-2010, 03:27 PM   #3
Will M.'s Avatar
Trailer: 1978 Trillium 13 ft
Ditto - I have always had to open the latch to close the door.
Will M. is offline   Reply With Quote
Old 11-25-2010, 10:30 PM   #4
Gumpit's Avatar
Massachusetts
Mine too. Randy
Gumpit is offline   Reply With Quote
Old 11-26-2010, 04:25 PM   #5
Rick G's Avatar
Smile
Originally Posted by Gumpit View Post
Mine too. Randy
Oh, so this is the infamous Bargman L400 then. I have not noticed it before, although it was easy enough to find on the internet once I had the model number. As previously stated, my old Boler had a different lock on it when I got it, and I replaced that with another different one.
Last week at a local RV dealer I saw a replacement lock cylinder for a Bargman L300 lock, and I think they also had one for the L400. I didn't pay much attention then, but I will go back there tomorrow and see if my memory is right, and if so I will pick it up.
Thanks, it appears that I will have to install the spring loaded striker assembly next spring, once I find one, if I want to have a nicely closing door. I will update this post when and if I do the install.
Rick G
Old 11-28-2010, 10:36 PM   #6
Rick G
I wonder if those cracks around the striker plate were caused by slamming the door. It appears like a good reason to NOT rely on the striker plate to push the latch in, rather use the handle to keep the latch in while closing the door, then release.
Old 04-01-2011, 07:07 PM   #7
Gumpit's Avatar
Massachusetts
BARGMAN L-400 / L400 ENTRY DOOR LOCK REPAIR KIT - eBay (item 230601201742 end time Apr-23-11 16:56:06 PDT) Just in case... It also comes with the lock cylinder and 2 keys
Old 04-01-2011, 09:10 PM   #8
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
You might check to see if the strike plate is loose. When I finally got the door on our 78 Trillium 1300 rehung it wouldn't latch when closed w/out retracting the handle until I repositioned the strike plate, that was loose , and bolted it in place instead of using rivets so it was good and secure. I also put a steel reinforcement on the inside w/ the fiberglass sandwiched between. Now with just a gentle push it latches nicely. A little spray lube on the lock probably helped too.
Reid Larsen is offline   Reply With Quote
Old 04-02-2011, 12:00 PM   #9
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Reid may be on to something, I originally noticed in the first picture that the door doesn't line up with the body, take a good look at the first picture.
Old 04-02-2011, 01:02 PM   #10
Raz
Raz's Avatar
Vermont
I think Bargman just recently stopped making the L300. Raz
Old 04-02-2011, 03:08 PM   #11
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I took my door off THREE TIMES in an attempt to "correct" its "misalignment".
Then I looked at pictures of BRAND NEW UNITS based on the original molds...and found out:
That's how they came/come from the factory!
Check 'em out:
Trillium RV 1500
Trillium Trailers - The Outback - Photo Gallery
Old 04-02-2011, 03:23 PM   #12
Greg H's Avatar
Indiana
Check 'em out:
Trillium RV 1500
That's kinda sad,the doors look like they leave the factory out of alignment, what a shame.
Old 04-02-2011, 04:35 PM   #13
Looking at your first pic it appears that the reveal on the strike side is very close. How much space or reveal do you have on the hinge side? In a perfect world the space around the door should be about the same. On my 78 1300 It was so tight on the hinge side bottom the door hit the jamb and the latch hardly hit the strike and it was as far off( or low) as your picture shows on the strike side. If you open the door and with it as closed as possible but free of the opening can you move it up and down or back and forth? In my case it moved alot, the hinges were worn out and had lots of slack and the holes the screw went into were all wallowed out. I bought new hinges ($$$!!!) and set the hinge screws (stainless) into threaded inserts( also SS) epoxied into the door and jamb. A time consuming and laborious task but worked. There are other solutions on the forum for curing the evil door sag. Good luck.
Old 04-05-2011, 04:33 PM   #14
Randy has posted pictures of some of his beautifully restored Trilliums in his "My Trillium Herd" thread. You won't find nicer restorations- perfect right down to the Factory Installed Door "alignment"! Somebody at Trillium Canada was OR when they built those molds back in the '70's...
See thread at My Trillium Herd!!!!!
trillium
Door Lock Errol Holbrooke Problem Solving | Owners Helping Owners 44 12-26-2011 09:25 PM
2004 Trillium Door Lock theresa p Problem Solving | Owners Helping Owners 13 11-29-2010 07:00 PM
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 07:11 AM
1974 Trillium door lock Barry Konkin Problem Solving | Owners Helping Owners 13 06-03-2009 09:56 PM
Door Lock-Trillium 1974/1300 Mary Lynn K. Problem Solving | Owners Helping Owners 4 04-15-2009 08:18 AM
