trillium factory A/C roof panel leaks - Fiberglass RV
Old 02-17-2014, 09:23 PM   #1
bobby62g's Avatar
Trailer: 1979 trillium 4500
my roof vent leak has led me to a much larger problem. I have discovered that the factory A/C panel has been taped, caulked & somehow stuck to the roof of my 78 trillium 4500. I have started removing the caulk after work, but I haven't figured out what holds the panel to the roof. Can I just use screws & sikaflex ? After a little web research I think eterna bond roof repair tape might work ,any thoughts ?
Thanks,
Bobby
bobby62g is offline   Reply With Quote
Old 02-17-2014, 09:48 PM   #2
bobby62g's Avatar
ok I see there are lots of strings regarding etrna bond both pro & con
leaks, trillium
Roof leaks allen jackson General Chat 2 09-23-2013 07:16 AM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
Solar panel mounted on roof Trillium 1300 je.bedard Modifications, Alterations and Updates 9 08-29-2012 03:36 PM
For Sale Trillium 4500 with factory installed roof top air logcabin Classified Archives 2 05-13-2011 04:16 PM
Mysterious leaks in Trillium 1300...maybe solved David Swinnard Problem Solving | Owners Helping Owners 3 06-11-2009 08:40 AM
