01-30-2012, 11:44 AM
Newfoundland
Trillium Frame
Hi all,
We recently aquired a '73 1300. I am wanting to remove the frame to blast/paint and do the recall frame fix while I am at it. I had a look under the trailer and I only se the two front bolts where the crack forms. Seems to be ok but I understand that there are 6 bolts holding the trailer on the frame. I cannot find any more than the 2 on the front. No empty holes either.
Any Ideas?
01-30-2012, 12:29 PM
Tom,
Take a look on the inside of the gaucho, you should see four bolt heads, or holes where there used to be heads. Under the dinette seats, there should be one under each seat.
01-30-2012, 01:00 PM
Newfoundland
Thanks David, I have seen those there but they look like screws to me. I was hoping for through bolts... I guess those suckers will need drilling out, I can't even tell the drive design or size due to rust. I figure I will drill holes through the frame and run SS bolts on reassembly. Maybe stiffen the frame there as well.
Hahahaha I guess they have been there almost 40 years I can't expect much.
Any tips on supporting the trailer to get the frame out?
I figure I would drill out the screws, remove the front two bolts, then jack up the trailer frame and all, then block up the trailer with wood and lower the frame. Maybe take the wheels off to make it easier to pull out.
01-30-2012, 01:54 PM
Trailer: 1996 16' Casita SD
Louisiana
I can't remember where I saw it, but there's another thread that explains how to do it. Maybe you could search it. I don't have much luck using the search function because I get distracted with other threads while looking.
Be sure to support the fiberglass in as wide a footprint as you can. You'll be safe that way.
01-30-2012, 04:00 PM
Newfoundland
Yeah the support will be there for sure. Don't want to crack my egg....
I have searched and get sidetracked as well.
01-30-2012, 04:34 PM
The folks at Outback / Trilliuim had my trailer off the frame. When I went to look at it I was supprized to see it sitting on a moving dolly. I am not sure what a 1300 looks like underneath, but the 4500 is not flat, it sticks out where the water tank is, under the dinette. The trailer was just resting on the front edge of the water tank protrusion and the front edge of the trailer. It looked kinda funny, (I will post pictures later). When I asked, they said that the cab of the trailer was not heavy enough to damage it. As far as I can tell, they were correct.
01-30-2012, 05:06 PM
Hello Tom and welcome. Not too long ago another member was dealing with a situation similar to yours. I will offer the same information I offered him. We have a new (2010) Trillium. It has 6 bolts. All attach to the frame through L shaped brackets welded to the side of the frame. I suspect this was done so as not to weaken the frame. Next, this is what I consider a very good thread on this subject (in particular entry #6).
http://www.fiberglassrv.com/forums/f...hem-37882.html
Tell me if you agree. Don't let the title mislead. Good luck, Raz
01-30-2012, 11:27 PM
Trailer: 1978 Trillium 4500
I unbolted my 4500 from the frame recently. Most likely the very first time since it was built in 1977. The bolts and nuts became a solid piece of rust.
I had 8 bolts. 4 in front, 4 in back. They were like carrage bolts, with large fender type washers. The head of the bolt was wedged firmly in the plywood/glass floor board. Took a bunch of "persuading" to get out.
I used a 7/16 extra deep socket with an 3 inch extension. Reached under the trailer, beyond the box girder frame, and found the bolt by reaching up and feeling. (Note, that the trailer was on the wheels). When I put torque on the nut, the bolts snapped.
You can see some picts of the carnage here:
http://www.fiberglassrv.com/forums/f...ion-49308.html
I bought some 2x6x10' boards to put under the egg when I jack it up. Haven't done that yet.
Don't forget the other things you need to disconnect:
* wiring to the Tow V.
* gas line (mine when thru the frame)
* electrical ground ground
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
01-31-2012, 07:27 AM
Newfoundland
I read that post on the Boler frame fastners, I agree with the L brackets like you mentioned. This would surely make it easier down the road.
I had a look at all the things I have to disconnect. My gas line runs through the frame as well.
01-31-2012, 07:46 AM
Originally Posted by David Tilston
The folks at Outback / Trilliuim had my trailer off the frame. (I will post pictures later). When I asked, they said that the cab of the trailer was not heavy enough to damage it. As far as I can tell, they were correct.
OK, I guess they used blocks as well. The underside shot is from the back looking forward. The water tank fills most of the frame. The edge visible ahead of the tank is where the floor steps up under the dinette.
In the picture of the frame you can see the two tabs at the back for the frame bolts. The other six bolts go through cross members.
01-31-2012, 08:12 AM
Newfoundland
Thanks for the pics. From what I can see on mine is I have 3-4 self tappers either side in the benches on the rear, and 2 carriage bolts through the outter frame on the front. I tried these nuts on the front today and the whole bolt turned and the head is sunkinto the plywood inside so it looks like hammer and chisel time.
01-31-2012, 08:19 AM
Newfoundland
Here is a shot of the front bolts. As you can see the frame needs blasting and the support done.
01-31-2012, 08:33 AM
Usually with spinning carriage bolts I would chisel the top just enough to grip with vise grips but in this case unless the floor needs replacing I would consider a nut splitter or just a hack saw or grinder on the nut. Soft steel. Shouldn't take long. Raz
01-31-2012, 08:41 AM
Newfoundland
Yeah thats my thoughts as well. Don't look like I will be doing any work on it today, lots of snow falling.
I think I will weld on 6 L brackets inside the frame, one each side near the original hole on the front, and two on the rear each side under the benches. Put some 1/2" or better SS nut/bolt/washers on there and call it done. That will be alot better than the self tappers they have in there now.
01-31-2012, 09:10 AM
Louisiana
My favorite tool for cutting rusty things is a 4" angle grinder.
It's always good to see these old things being taken care of!
01-31-2012, 10:46 AM
Ours came with 7/16" ss bolts. Unfortunately they were too long and would not tighten. Adding 5 washers was sloppy, so I bought the correct length. Of course if you go to the hardware store and look for 7/16" ss bolts you won't find them. They stock 3/8" or 1/2". Go figure. While I could have drilled things out to 1/2"' the L brackets are small to begin with. I ordered online. I guess my point is make sure you get your hardware before you drill your holes. Raz
01-31-2012, 11:46 AM
The factory configuration is four bolts in the gaucho, and two under the dinette seats.
The cross member in your picture. Is it a C channel? if so, no tabs necessary there. Just drill into those. The only place that you need tabs is where you don't have a cross member.
It is difficult to describe, but the angle iron tabs on my trailer are welded perpendicular to the frame. The weld itself forms an L shape.
I also noticed that your trailer does not have plates welded at the bend / bolt hole location. This was a design change after the factory experimented with heat treating the frame. It was the heat treating that caused the cracking problem. The solution was to weld the plates on either side of the square tube around the hole. The factory did this to my trailer, even though there are no bolt holes through the square tube. One of my cross members is welded to the plates that are on the inside. This point on the frame is practically half way between the axle and the hitch. A very high stress point. It may be advisable for you to consider putting on these plates as well.
01-31-2012, 05:47 PM
Newfoundland
Yeah I plan on adding the modification to the frame when its blasted. I assume the gaucho is the front couch? If so the only bolts here are the two carriage through the frame, then there are the 4 under the bench on each side on the rear. Looks like 3 in the frame and one in the cross member so the 4 under the bench kinda make a upside down L, but all seem to be screws, nothing coming out the other side of the frame and no holes. We will find out I guess when I hack it out. Previous owners may have changed it around.
02-01-2012, 07:03 PM
Newfoundland
OK have it off the frame. Like I said two in the front bench and 3 rusty screws on each side under the benches. Just chiseled the heads off the screws and pulled it through the bottom.
I jacked it up using a Hi Lift jack in the wheel wells with a board to distribute the weight. I stacked 2X4s on the frame until I could get the 2X6 boards I nailed together to create a 6X6 underneith. So far I have the rear off the frame totally but need to pick up two more jack stands to get the front off the frame. Then slide the sucker out.
02-01-2012, 07:55 PM
Nice. Great pictures too. Thanks.
Cheers
--Fred and Natalie
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Need a new Frame :-(
ursulap |
6 |
07-05-2009 08:28 PM |
Frame sag
Tom B. |
12 |
01-18-2009 10:14 PM |
Pizza Pop Commerical with a Trilluim 5500
Kenny H |
General Chat |
0 |
11-18-2008 04:22 PM |
FRAME
JIMZ |
53 |
02-17-2008 11:05 PM |
Boler Frame
RobJ |
6 |
03-19-2007 03:16 PM |
