Trillium Frame - Page 2 - Fiberglass RV
Old 12-09-2013, 09:22 PM   #21
Originally Posted by David Tilston View Post
Floyd, I agree that the step is not especially large, but it reflects a step in the frame as well. this step in the frame actually happens before the axle, so the floor from that point to the step in the fibreglass is sitting below the frame. If the body were put on a flat frame, then it would be a good idea to put something in the place of that step in the frame. Not a big deal, just a good idea.
I can't imagine any mod like this would be done without a little tweaking.
But it would still be quite an easy mod at least worth looking into.
Last time I checked on a new 6X10 trailer frame ready to tow with a 2200# axle, it was something like $700... A nice start which should certainly bring the mod in under a grand. I would likely start with a used utility trailer,atape measure, a cutting torch and a MIG.
Of course there may be some reason that such a mod would not be practical but it sounds unlikely.
Sorry, It was not my intention to engineer it completely here, it was meant to be a suggestion worth mentioning.
I do know that if I set out to do it I would...
Old 12-29-2013, 03:27 PM   #22
here are some pictures of the Trillium the day that I bought it.
1976 and serial # 1202525
furnace ,dometic 211 fridge,front gaucho
Craig Broughton is offline   Reply With Quote
Old 12-30-2013, 12:07 PM   #23
how do you post pics
MAP 56 is offline   Reply With Quote
Old 12-30-2013, 12:39 PM   #24
David Tilston's Avatar
http://www.fiberglassrv.com/forums/f...tml#post217275
Old 12-30-2013, 12:49 PM   #25
Craig, I am assuming that the serial number is actually, 13-1202525. This puts it in the 1974 to 1975 range. Just above your pressure regulator, you seem to have the remnants of a date sticker. Is it readable at all?
Your furnace appears to be a Duo-Therm, from the outside vent. The model # would be on a name plate that you can only see when you remove the cover. Does it look like the attached picture of my broken egg?
I was working on the drawing of a 1300 frame last night. should be done soon. I think the frame is different on each of my 1300's. The one I am drawing is the 1977, but I have a 1972 and 1973 as well.
Old 12-30-2013, 03:39 PM   #26
Yes David the serial number is 13-1202525 the tag above the regulator is worn off with stone chips however there is a aluminum tag on the side of the trailer down by the wheel that has a date stamp 76/03/23 along with the serial number.Same furnace, same interior green with dark door panel color. I have never had one with a furnace how do you open the door for lighting?Is It on a pivot/hinge that swings to the left?
Old 12-30-2013, 04:31 PM   #27
The knob is used to pull the front off the furnace. The metal is thin, and it may have rusted on. Maybe try prying it off at the corners, so you don't damage the cover. Later models had a hatch that pulls off. Then there is a small hatch over the pilot light. You will need to loosen two thumb screws, and it will rotate to reveal a hole for lighting the pilot light. Use a lighter to shoot into that hole, then press down on the valve till the pilot light lights. Actually it takes a bit after it lights to heat up the thermocouple, so it will stay on. Then switch to run and adjust the temperature selector to taste.
I'd sure like to see a picture of that tag.
Old 12-30-2013, 04:51 PM   #28
I will quickly run out and see if my camera will take the picture it is getting dark and VERY cold here ....I will be right back
Old 12-30-2013, 04:59 PM   #29
Ah well... I am afraid that none of those would be good to date the trailer. The one that looks like it was done by hand, was almost certainly done after purchase. I know it is illegible, and cold, but could you get a picture, like the ones you posted, but of the sticker above the regulator? Sorry to be such a pain.
Old 12-30-2013, 05:17 PM   #30
here we go not much to show you but three pictures at different angles and some good old Winnipeg snow-30 right now with windchill-38 they are calling for -51 with windchill tonight....
Old 12-30-2013, 07:36 PM   #31
Thanks, I kinda figured it was a futile effort, but I have a hard time giving up. That is a manufacture date sticker, but the date is gone.
Sorry to make you freeze. Thanks though.
Old 12-30-2013, 09:50 PM   #32
If the date is in the top left ? In the first picture I can see a faint number ending with a 6
Old 12-30-2013, 10:20 PM   #33
Manufacture date stickers are kinda rare on the later Trilliums. Maybe they used a less sturdy material, later on. The one that is closest in age to yours that has one is:
http://www.fiberglassrv.com/forums/f...tml#post374110
The serial number is in the upper left and the manufacture date is in the lower left. The six that you see is likely a 5 at the end of the serial number. When they are in that bad of shape, they kinda look alike.
trillium
Trillium 1300 Frame Question Ruth C. Problem Solving | Owners Helping Owners 20 03-15-2013 06:27 PM
Broken Trillium 13 frame bernfp Towing, Hitching, Axles and Running Gear 7 09-06-2012 03:24 AM
Trillium Frame Duke79 Problem Solving | Owners Helping Owners 31 02-02-2012 08:52 PM
1979 trillium frame Ryan Kennelly Classified Archives 2 08-25-2006 05:09 PM
Trillium Frame Concerns Joseph Olajos Problem Solving | Owners Helping Owners 28 04-12-2006 03:35 PM
