Trillium Frame Concerns; Repair Update - Fiberglass RV
Old 04-28-2006, 07:07 PM   #1
Trailer: 1989 17 ft Bigfoot Deluxe / 2004 Ford Ranger
Following up on advice gleaned from forum readers, I had the frame reinforced on our '73 Trillium today. Side plates (gussets) consisting of 2"x 16" diamond-shaped 1/8" steel were welded to both sides of each front section of the A-frame in an area from about 4" behind the f/g shell anchoring bolts to about where the frame is "dimpled" from the factory bending process.The work was done at a custom welding/fabricating shop here in Peterborough; 2 hours of labour and material, the bill came to $161.00, taxes incl.... as well, they installed two new anchor bolts, and painted the areas of the welds...especially between the frame-top surface and f/g shell, since they had to raise the shell somewhat to prevent heat damage while welding the top edges of the gussets. At my request, they also did a once-over insp'n of the entire frame(while up on the hoist),and declared it to be still in excellant shape and quite sound.
A profesional job, to be sure, and at a fair price; can't beat that !
Joe
Joseph Olajos is offline   Reply With Quote
Old 04-28-2006, 09:06 PM   #2
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
Sounds ALMOST Egg-zakerly what Reace at Escape Trailers did for us in the line of updates when our Trillium was in his plant!!!
Old 03-08-2015, 08:48 AM   #3
Trailer: 1976 trillium
hi we have a 76 13ft trillium that is honeycombing on the front.does anyone know a good fiberglass shop in on. thanks old yeller
old yeller is offline   Reply With Quote
Old 03-08-2015, 12:44 PM   #4
Mom2philip's Avatar
Trailer: 1973 Trillium
When you have a chance can you take some pictures? I think we might need to do that as well.
Thanks!
Mom2philip is offline   Reply With Quote
trillium
13' Burro frame repair. Rozanne G Problem Solving | Owners Helping Owners 7 05-29-2008 03:16 PM
Trillium 4500 Frame Repair Query gouldmorrison Problem Solving | Owners Helping Owners 4 12-06-2007 03:05 PM
2004 Trillium Update Chester Taje Modifications, Alterations and Updates 20 08-09-2007 09:53 PM
Trillium Frame Concerns Joseph Olajos Problem Solving | Owners Helping Owners 28 04-12-2006 03:35 PM
Trillium Portable Toilet Repair Legacy Posts Plumbing | Systems and Fixtures 7 01-31-2003 06:46 PM
