Trillium Front Door Window - Page 2 - Fiberglass RV
Old 09-05-2016, 10:54 AM   #15
Trailer: (4) Trillium 4500, (4) Trillium 1300, (1) Scamp,(1) Burro 16'
Ardmore, Alabama
I had the same issue with mine but it had shrunk so much it was 2" inches short... My glass guy tried to find the seal but no luck so day before yesterday I pulled the old one out put in a pot of bleach boiled it for 15 minutes took it out and stretched the dog crap out of it, left it out in the Alabama sun most of the first day and all day yesterday and re-installed it yesterday evening.. turned out to be 1" too long but I kept rubbing it and coaxing it till I got it re-installed and so far looks great... Might shrink in the coming months when it gets cold, thought about gluing it in but thought better of it, would be very hard to get it out if I ever needed too....
Randy Bishop is offline   Reply With Quote
Old 05-18-2017, 05:40 AM   #16
JRTrillium's Avatar
Name: Janice & Rick
Trailer: Trillium 1300
Nova Scotia
Reviving the Trillium door window gasket thread
Hi - Still looking for the gasket, trim, not sure what it should be officially labeled - has anyone had any luck with a supplier, dealer, garage?
We took ours out last night for a good scrub and possible lengthening?
I took a picture of the end of it. Hoping this post will revive some interest.
JRTrillium is offline   Reply With Quote
Old 05-18-2017, 05:42 AM   #17
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
Thanks, Randy! That is about what we have in mind for right now. Very glad to know you had some success with it!
Old 05-18-2017, 10:26 AM   #18
Larry C Hanson's Avatar
Window seal?
Hello,
Here is one from Vintage Trailer Supply. Might work?
Glazing Strip for Vintage Hehr Hallmark 12 1201 1202 Window
Larry H
Old 07-09-2017, 09:01 AM   #19
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
I am reviving this conversation, hopefully, in that someone has discovered a good replacement. Colleen wrote that she solved her problem and it was simple - would love to hear what that was. Thanks all.
Old 07-09-2017, 09:32 AM   #20
John in Michigan's Avatar
Trailer: 1978 Trillium 4500
I believe it is Interstate 009-344 as mentioned in this post:
Boler 1700 Window Seals
Disclaimer: I have not purchased this seal or tried it. I do have the problem with shrunken window seals on my Boler 1700, but am putting off replacing them. So far, I have started cleaning the window seals and temporarily filling the gaps with color-matched DAP Dynaflex 230 caulk.
Edit: Currently I am pulling the windows, cleaning, sealing and re-installing with a double layer if 1/8" thick butyl tape. Sealing the radius window seals with DAP Dynaflex 230 caulk as a stop-gap measure to stop water intrusion. At some point I will probably replace the seals.
Old 07-09-2017, 11:33 AM   #21
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
Thanks - have looked and looked through the links - I don't believe the Trillium gasket for the door window exists anywhere
Old 07-09-2017, 11:48 AM   #22
JRTrillium, the Interstate 009-344 profile photo posted on the Interstate website sure looks like the profile photo you posted. Also, 009-311 and 009-479.
I did a general search "hehr 009-344" and found several web stores that sell a seal with that profile.
Old 07-09-2017, 12:23 PM   #23
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
OK - I will look again - thank you.
John in Michigan!! You are right - that is it. I don't know how I missed that. Now it's just a matter of seeing if it's actually available - will definitely post here to let folks know. Thanks for double checking for me.
trillium
Wanted: WANTED - Trillium 1300 - Shelves, door window, kitchen window and frame David Tilston Parts: Buy | Sell | Trade 6 10-20-2012 10:13 PM
Boler Door and front window trim Lori Appleyard Problem Solving | Owners Helping Owners 12 03-21-2012 11:19 AM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 05:30 PM
Old side window & door window needed sherry loving o Classified Archives 0 06-12-2008 04:15 PM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 08:21 AM
» Virginia Campgrounds
