Trillium Front Door Window - Fiberglass RV
Old 05-08-2016, 05:52 PM   #1
JRTrillium's Avatar
Name: Janice & Rick
Trailer: Trillium 1300
Nova Scotia
Hi - I have a door window that needs some addressing - the seal is pulling away from the frame of the window - is this a self repair thing or do I need to take it in to a window shop.
I will include pictures to help you see. Well thought I would but not sure how to do it.
Thanks for looking!
JR
JRTrillium is offline   Reply With Quote
Old 05-08-2016, 07:13 PM   #2
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
I am having a hard time attaching photos for you to see.
Old 05-08-2016, 07:18 PM   #3
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
Trillium Door Window
Hope you can see the window issue here.
Old 05-08-2016, 07:19 PM   #4
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
Larger Window Pics
Finally managed to attach pictures. Thanks for patience.
Trillium Door Window May 2016IMG_1450.jpg   Trillium Door Window May 2016IMG_1451.jpg
Old 05-09-2016, 09:45 AM   #5
Larry C Hanson's Avatar
SEAL?
Hello,
It is hard to tell the problem from the photos.
Is the seal you are concerned about between
the aluminum frame and the fiberglass door
or between the glass and the aluminum frame?
Larry
Old 05-09-2016, 11:24 AM   #6
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
Hi Larry,
Thank you for responding. If you click on the exterior window picture it will be a larger view (it is for me anyway) and you will see the two lower corners the rubber seal thingy is coming away from the metal frame - this is all exterior.
You should also be able to see a while silicon-y thing I would be able to pick out with my fingers - it looks like someone has done a quick fix?
Hope this explains things better.
Janice
Old 05-09-2016, 11:30 AM   #7
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
This photo shows an explanation
Here is a better photo I hope - I explained a couple things on it. I do not know how to remove the first image - it is too small. The second one can be read easier.
The issue is between the front glass and frame.
Janice
Old 05-09-2016, 08:51 PM   #8
Colleen C's Avatar
Trailer: 1979 Trillium 4500
I had the same issue with both my '77 1300 and '79 4500. Like the vinyl insert in the belly band, with time, these shrink. I found out this is a type of spacer to keep the window protected within the frame; the glass is set in and adhered to the aluminum frame. The aluminum frame is set into the door with butyl tape as the other windows should be.
I carefully pulled away about 1/2" from the window and drew a picture of the side view. Took another trip to my local RV store/service company (in Seattle, it's Evergreen RV) and bought a length from the service area. Pulled out the old/brittle/shrunken seal, pushed in the new and it looks beautiful! One of the simplest fixes on the trailer!
Colleen C is offline   Reply With Quote
Old 05-10-2016, 04:38 AM   #9
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
Colleen, Thank you! Hopefully I will find this an easy fix. I thought maybe I had to have the window removed or something!!! I will post a picture when I get it fixed . . . . by us.
Why do you think there was silicone there? Is that normal or a quick fix by someone else you think?
Old 05-10-2016, 09:16 AM   #10
David Tilston's Avatar
Colleen, Would it be possible to get a manufacture and model number of the part that worked for you?
Old 07-25-2016, 08:17 AM   #11
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
David - Did Colleen write you about the model number for the seal for the front door window? Would love to know.
Old 09-04-2016, 05:52 PM   #12
Roy in TO's Avatar
Well I am looking for the same seal. I sent Colleen a PM, hopefully we will all find out soon.
Old 09-04-2016, 07:22 PM   #13
Roy in TO's Avatar
My seal specs
Considering a bunch of us are looking for the same thing, I thought I would post some pictures and specs.
I measure the profile as ~ 0.500" wide and ~ 0.425" tall.
The profile to a metric ruler
And the seal seated in the window frame, the longer arm spans the glass.
Old 09-05-2016, 05:33 AM   #14
JRTrillium's Avatar
Name: Janice & Rick
Nova Scotia
Great idea - thank you for posting pic - hopefully someone will find it soon - I have a neighbour down the road from me who will be taking my trailer for a couple weeks and doing some work on it.
trillium
Wanted: WANTED - Trillium 1300 - Shelves, door window, kitchen window and frame David Tilston Parts: Buy | Sell | Trade 6 10-20-2012 09:13 PM
Boler Door and front window trim Lori Appleyard Problem Solving | Owners Helping Owners 12 03-21-2012 10:19 AM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Old side window & door window needed sherry loving o Classified Archives 0 06-12-2008 03:15 PM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
