Trillium Furnace - Fiberglass RV
Old 07-18-2018, 05:08 PM   #1
Trillium Furnace
I am in need of a furnace for my 84 Trillium 1300. Does any one know what modern furnace could be used? Fiberglass work, no problem, as long as it is a working furnace. It seems the length is the issue.
Any suggestions?
SenseiPete3x4 is offline   Reply With Quote
Old 07-19-2018, 09:54 AM   #2
David Tilston's Avatar
Pete, A couple of things:
- Trillium stopped manufacturing trailers in 1982, so yours is likely not a 1984. You can compare your serial number to this list to help determine your correct year:
A lesson in Life
- The furnace in Trilliums was originally what is known as a gravity furnace. These were installed below the sink in 1300's and below the closet on 4500's. They are basically a fire in a box. No electrical requirements, low efficiency, high surface temperature. Around 1979 they were considered a fire hazard. I have not heard of any fires from this, but it must have happened for them to be banned. In the 1300's they replaced them with a Coleman 4312:
http://www.fiberglassrv.com/forums/d..._Operation.pdf
One of these in a Trillium can be seen in the following link:
Fire in Trailer
As you can see there were several modifications to the fibreglass. Some have said that the closet looks pregnant.
In the 4500's I have seen several different forced air furnaces installed in the curb side seat of the dinette. I can't figure out why that was not done with the 1300's
Old 07-19-2018, 05:10 PM   #3
Thanks Dave for all the good info.. I think I'm still looking to use a modern furnace, but in the same location as the old gravity one. The problem is the cabinet depth. Most that I have looked at like the Suburban NT16 SE have a length of aprox. 24 in., my cabinet is aprox. 171/2 in.. Any input would be appreciated.
Old 07-19-2018, 05:47 PM   #4
Pete, That is why Trillium had to make a pregnant closet. I don't think you will find a forced air furnace that fits under the sink. Otherwise Trillium would not have made this compromise. If you plan to use a modern furnace, then I think your best bet would be to install it under a dinette seat.
Probably your best option would be a Propex furnace. They are not cheep, but those that have installed them seem to like them:
http://www.fiberglassrv.com/forums/f...ion-63501.html
http://www.fiberglassrv.com/forums/f...s-64768-4.html
https://www.propexheatsource.co.uk/h...r-installation
http://www.fiberglassrv.com/forums/f...ion-71235.html
Ca. Desert Winter Warm-up Feb.9-12, '07
But personally, I like the original gravity furnace under the sink, in front of the wheel well, where it uses space that would otherwise be wasted.
Old 07-23-2018, 01:13 PM   #5
Another thread about a Propex furnace:
http://www.fiberglassrv.com/forums/f...ere-84359.html
furnace, trillium
I am looking for a gravity furnace (old style furnace) fred wark Care and Feeding of Molded Fiberglass Trailers 9 04-01-2017 03:51 AM
Trillium 1300 furnace removal... David Swinnard Problem Solving | Owners Helping Owners 7 11-28-2015 12:37 PM
Trillium 4500 Furnace Mic Shaw Problem Solving | Owners Helping Owners 7 10-04-2015 03:54 PM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
Furnace exhaust grille for Trillium wanted Kevin242 Classified Archives 2 04-13-2009 08:22 AM
