Trillium Jubilee '79 floor replacement, leak. - Fiberglass RV
Old 04-27-2014, 02:13 PM   #1
Trailer: Trillium Jubilee '79
Newfoundland
Hi, folks.
Just removed original flooring from our 1979 Trillium Jubilee. Wondering what adhesive is best and easiest to use to adhere the new 3/4" plywood floor to the fibreglass body? Any /all suggestions appreciated.
I looked to purchase something like Liquid Nails but not sure how it would work if there's a leak and water infiltrates. Speaking of leak, how would I best go about removing the cap over the belly band to check the integrity of the weather seal? Other possible areas to check??
Many thanks in advance.
Paul :-)
Terranovafox is offline   Reply With Quote
Old 04-27-2014, 06:56 PM   #2
Newfoundland
Hi, folks. Not sure if this helps. Here is a little more information by way of explanation giving context to my questions. Most of the original 3/4" plywood floor was glassed in except for the area covering the water reservoir under the table. That was anchored to the glassed-in plywood with hinges. I'm assuming the glassed-in subfloor was to add structural stability to the trailer. Four bolts also anchored the subfloor to the trailer chassis. These will be replaced with new. To remove the old flooring was easy and hard (tedious). The easy parts (rear corners) fell apart in my hands. For the remainder I set the depth of my circular saw to just shy of 3/4" and then pryed, chiseled and scraped the rest. The storage areas of the benches/bed were wood frames which I disassembled and removed. Now I have one big open floor ~71" by ~ 49".
Old 04-30-2014, 02:02 PM   #3
Newfoundland
Update.
The folks at Liquid Nails indicate that Liquid Nails Polyurethane Construction Adhesive (LN-950) should work well to bond plywood to fiberglass. Contact info (1-800 and email support) can be found on their website. See below.
http://www.liquidnails.com/adhesive-...-caulk-contact
Old 05-04-2014, 05:22 AM   #4
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
How about some pictures. They show things way better than descriptions do
Old 05-04-2014, 06:16 PM   #5
Newfoundland
Joe,
I can't seem to manage to get pictures to upload. Sorry.
Today I finished putting everything back together and all looks well.
Paul
trillium
Trillium Jubilee Wood Floor Replacement rcaulen Problem Solving | Owners Helping Owners 4 08-31-2011 04:09 AM
1979 Trillium Jubilee for Sale Tim R Classified Archives 13 08-24-2009 06:33 AM
Trillium Jubilee Tim R General Chat 1 05-19-2009 09:41 AM
'79 Trillium Jubilee 4500 $5350, Otter Lake Quebec GlenP Classified Archives 0 04-17-2009 10:38 PM
Trillium floor replacement chemong Problem Solving | Owners Helping Owners 14 07-04-2006 06:28 PM
